Pump suggestion for my underground tank
                    rguruprasath
                    Registered Users Posts: 9 ✭✭
                    Hello, I need some suggestion for my underground tank pump. Basically the underground tank is not so deep, roughly of 4 foot high and ground just below the surface.
The pump job is to simply lift the water from the tank and supply to kitchen. 4 feet of depth + ~10 feet of flat surface pipe to kitchen is all the requirement. I'm looking for a minimal setup as this is for rain water storage.
Your suggestions please.
            Are you OK with a 12 volt or 24 volt RV water pump? Cheap (some are cheap, can get expensive versions too), easy, does not use much power. Add a small pressure tank to buffer the pump? Some pumps have pressure switches built in. Several years of life between rebuilds (replacing diaphragms).
If you have AC power (Mains/Off grid inverter), AC pumps will usually last longer.
            I'm OK with both 12V DC as well as AC powered pumps. I can see either totally under powered pumps (say dc pumps used for aquarium) or little high powered AC pumps like 0.5HP I'm looking for something in the mid range, I couldn't find one.
            Shurflo would be a start for DC pumps:
https://www.solar-electric.com/catalogsearch/result/?q=shurflo
Lifting water is always a bit of an issue--Any dirt on the inlet filter, air leaks in the lift pipe makes for a pain (trying to find leaks, pump air locks, etc.). 4 ft of lift distance is not near as bad as 10-15 feet of lift.
If you can put the pump outside the tank and pipe it to the base of the tank, positive pressure feed helps a lot. But, you have to design that if there is a fitting/pipe/pump failure, the water leak does not flood the basement/wash dirt away from the base of the tank.
An in tank/submersible pump is nice--But they are much more expensive.
            Agree with Bill.
Shurflo on demand 12v pumps are very dependable. Before I built out my off grid system years ago, I used these on demand pumps to supply the house between the storage tank and the house plumbed with ranch pipe and pvc. Cheap and reliable soution.
If I remember right they were between 3 and 5 GPM.
Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers -
            Also add a small pressure tank. More, smoother flow, longer brush life.
 - 232 Forum & Website
