Correct wire gauge for a newbie.
jm0963
Registered Users Posts: 1 ✭
First time poster here.... I have scoured the forum and can't seem to find the information i am looking for. I have recently begun getting acquainted with a simple solar set up and am having trouble discerning what wire gauge to use in my system. I have (2) 135 watt panels that will run to a MPPT charge control (50 feet away) and that will run to a (4) marine/rv battery bank. I've seen everywhere from 4 gauge all the way to 10 gauge.....any suggestions?
It depends on how much loss you can stand. Generally, less than 3% in the wires between PV and battery is the goal.
here's 2 links, first is a zipped, protected SpreadSheet with all sorts of user input and it tells you the loss, (instructions at bottom of sheet) 2nd is some discussion
Calculator spreadsheet
http://www.solar-guppy.com/download/voltage_drop_calculator.zip
more calculator options and discussion
http://www.solarpaneltalk.com/showthread.php?2312-Wiring-interconnect-goodies-amp-volt-drop-loss-calculator
Here is simple voltage drop calculator:
http://www.calculator.net/voltage-drop-calculator.html
So, plug in:- 135 Watt panel / 18 volt Vmp = 7.5 amps Imp
- 50 foot (one way run)
- 2x18 volts Vmp = 36 volt array (nominal)
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=5.211&voltage=36&phase=dc&noofconductor=1&distance=50&distanceunit=feet&eres=7.5&x=48&y=13
12 AWG
Voltage drop: 1.19
Voltage drop percentage: 3.31%
Voltage at the end: 34.81
8 AWG
Voltage drop: 0.47
Voltage drop percentage: 1.31%
Voltage at the end: 35.53
What if you used something like 14 AWG? (smallest AWG I would suggest for outside wire runs):
14 AWG
Voltage drop: 1.89
Voltage drop percentage: 5.25%
Voltage at the end: 34.11
You will lose about 5% of your systems output in the middle of the day (power=voltage*current, cut voltage by 5%, cuts power by 5%).
So there is your range--Would the system work with 14 AWG--Yes, just fine. But you will be losing around (5% * 270 watts=) 13.5 Watts in the middle of the day (full sun, full rated current).
Could use use heavier than 8 AWG cable--Yes, but you would be spending lots of money for very little return.
If you are burying the cable--Perhaps you would want a heavier cable if you eventually add two more solar panels. Or--Bury a larger conduit so you can pull more/new/heavier cable down the road and not worry about retrenching.
Just to give you an idea, every 3 AWG reduction in wire gauge is 2x more copper (and roughly 2x higher costs for cable). 14 AWG to 8 AWG is 6 change in gauge, or 4x more copper for 8 awg cable and 4x higher costs for cable.
- 230 Forum & Website
