HELP! New to Solar and moving soon!
JessicaF
Registered Users Posts: 1 ✭
This is all becoming very confusing to me...I am moving into a tiny house 240 sq ft. the only thing that we need to run is 4 led lights and a refrigerator that estimates 337 kWh per year so I figure that is less than 1 kWh per day. We have looked at a starter kit that has 2 - 100 watt panels that is slated to produce 25 amp hours a day for a total of 50 and/or 300 watt hours for a total of 600. I have looked at 2 12 volt batteries from Cabellas to start as I know that we need to get better more expensive ones soon but just trying to get moved in on a tight budget. Any help would be most appreciated! Thanks in advance.
have you already got the fridge bought? if so can you bring it back. with such a small house i think you should be looking into dc fridge's instead and 2 golf cart battery's600 watts of solar panels,Epever 30 mppt , 2 PWHR12500W4FR battery's in 24 volt setup
Standard AC induction motor compressor 120 VAC refrigerators have very high starting current (over 1,000 VA is not uncommon). And if self defrosting, may draw 200-500 Watts for a period of time.
In general, a 1,200 to 1,500 Watt AC inverter is recommended for running a standard energy star refrigerator... That works out to a minimum (for flooded cell deep cycle batteries) of ~480 AH @ 12 volt or 240 AH @ 48 volt (basically, 4x 6 volt @ 220 AH golf cart batteries minimum). Note that 6 volt golf cart batteries are generally a very good starting battery (cheap, pretty rugged, flooded cell can use a hydrometer to monitor charging)--And there is a good chance you will murder your first bank or two--So golf cart batteries are a good starter set.
If you are drawing 1 kWH per day from the battery bank, 2 days of storage and 50% discharge would be:- 1,000 WH * 1/0.85 inverter eff * 1/12 volts * 2 days storage * 0.50 max discharge = 392 AH @ 12 volts (or 196 AH @ 24 volts)
For full time off grid--It is really good to have 10% minimum rate of charge (5% to 13% typical solar range--5% for weekend/summer use, 10%+ for full time off grid):- 440 AH * 14.5 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 829 Watt array minimum (based on battery bank capacity)
http://www.solarelectricityhandbook.com/solar-irradiance.htmlAtlanta Georgia
Measured in kWh/m2/day onto a solar panel set at a 56° angle from vertical:
So, (guessing) Atlanta--Little genset use with 3.52 hours of sun (December average):Jan Feb Mar Apr May Jun 3.55
3.96
4.86
5.24
5.36
5.00
Jul Aug Sep Oct Nov Dec 5.18
5.01
4.82
4.92
3.96
3.52
- 1,000 Watt*hours per day * 1/0.52 off grid system eff * 1/3.52 hours of sun per day (Dec) = 546 Watt array "break even" December
Note--If you can get a DC refrigerator (not propane or tri-power ammonia type)--Your surge current drops way down and you can use a 1/2 size battery bank (2 golf cart batteries) and a smaller solar array (and save the AC inverter).
Small house--No computer, cell phone, clothes washer, pressure and/or well pump, etc.? 120 VAC refrigerator typically are what drive folks from small (500-1,000 WH per day) to medium size solar power systems (nominal 3.3 kWH per day for a very efficient off grid home is a good aim point).
Power usage is a highly personal set of choices. And for a cost effective off grid solar power system, choosing very power efficient appliances (and minimizing energy usage) is usually key.
- 234 Forum & Website
