Specific gravity readings from my bank?
bc buck
Registered Users Posts: 59 ✭✭
I feel my battery are getting weak so I bought a specific gravity tester. They show there charged but im getting about 1/2 AH there rated for. They are Trojan SCS 225.
Battery #1 readings.
1.26
1.257
1.257
1.25
1.257
1.263
Battery #2
1.255 1.260
1.264 1.263
1.265 1.265
What do these # represent?
1.26
1.257
1.257
1.25
1.257
1.263
Battery #2
1.255 1.260
1.264 1.263
1.265 1.265
First, know thatI am not an FLA man, I have AGMs.
So those numbers are telling you the relative charge of your cells. You need to look up the SG reading you should get for your mdel and date of production, some are in the 10265 range and others ~1.280.... there are a couple of very recent threads on these batteries, like in the last few days. do a search , lots of relevant info there for you ...
the 1.25 cells may need an EQ charge. Are you getting to FLOAT frequently?
These battery where abused for three years just using a generator. Now have panels and thinking EQ charging might put some more life in them.
what do you have for a charge controller and solar capacity?
Are you familiar with the procedures to do a good charge followed by an EQ?
450W using Morningstar MPPT controller and 260 AH battery bank.
Here is your Data sheet, http://www.trojanbattery.com/pdf/datasheets/SCS225_Trojan_Data_Sheets.pdf
Also http://www.trojanbattery.com/product/scs225/
Assume you have a 12 V system, you will need enough solar to have at least 26A at 16.2 Volts, to do an EQ and possibly more for Temp Compensation depending on your areas ambient temperature.
Thanks Westbranch that is good info.Just looked at instructions for Prostar mppt 40a charger. The voltage programmed into controller is set for 15.3v during the equalizing charge for flood battery. Looks like I will need to use the custom section to enter 16.2 v during equalizing. Will let you know if it helps refresh battery and get back some AH.
I would think that the strict use of a generator to keep batteries charged would be quite hard on them. Possibly drained pretty heavily at times....for three years. We don't know the recharge rate at this time.
Checking SG at the start of the day...before they are fully charged....may yield useful data. These SG figures don't look too bad to me. Though various manufacturers employ various SG parameters.
- 612 Discussion Forums/Café
- 305 In the Weeds--Member's Choice
