Trace 4024
Check the DC input voltage at the Inverter... If you have poor connections (or weak battery bank), the DC input current will rise (power=voltage*current; if DC voltage falls by 20%, the DC current rises by 20%).
Otherwise, it is possible that the inverter itself has failed. For example, there are pairs of FET (transistors) that, if both transistors were on at the same time (i.e., control circuit failure or transistor failure), it makes a dead short and can trip the input breaker/fuses.
Here is one thread about some debugging...
http://forum.solar-electric.com/discussion/7295/trace-sw4024-issue
But your inverter is something like 15+ years old... Parts may be difficult to find and it may be time to think about replacing it.
tbear..,
Which breaker is tripping -- a breaker on the AC output, or more likely, the inverter main DC breaker.
When the inverter has the Error light, illuminated, you can look in the Menu item, called ' Error Causes '. Of course, if the DC breaker as tripped, this will not work so well.
Are you noticing any issues with the battery on this system?
What is the current rating of the DC breaker that supplies the inverter DC from the battery?As Bill mentioned, check ALL connections are tight and that there is no sign that the terminals or cables have overheated.
Is there any chance of a nearby lightning strike?
Do you have the Manual for this inverter? It can be found on-line, but it is almost 3 MB, and about 150 pages, not too phone-friendly ...
Please tell us as much about the details of the system as possible. Thanks, Vic
No breaker is tripping it says it is 250 amp dc breaker no lightening strikes have the manual frustrated it goes on for hours or days then error messages won't go on then when shut down doc ond turn on sounds like shorting in inverter then eventually is will go on again
Inverter will sometimes shut itself of no error message not consistent
tbear31818 said:No breaker is tripping it says it is 250 amp dc breaker no lightening strikes have the manual frustrated it goes on for hours or days then error messages won't go on then when shut down doc ond turn on sounds like shorting in inverter then eventually is will go on again
tbear..,OK, sorry had a bit of trouble decoding just what you were saying.
That 250 ADC breaker is what this inverter should have.
Try removing ALL loads on the AC out side of the 4024. Does this change any of the issues?
These units have a history of the Relays having welded contacts. This could, possibly cause unpredictable behavior. On the later model of this series (the SW +), the relays are in the lower left side of the inverter. Do not know the area where the relays are in the Trace SWs, but, some say that give a bit of a smack with your fist on the side, and possibly the front to the inverter's case ... could not really hurt.Normally one would say to check all connections for tightness, but the sounds of a short (assume that this is a loud hum, or buzzzzzzz) would imply a short of some kind, and that perhaps one of the current sense circuitry does not work ...
A short on the AC output side, would normally cause the inverter to Fault - OFF in a very short time. Depending upon the nature of any AC short, the behavior and sounds from the 4024 would be different, if it is operating properly.
A Trace 4024 inverter is a Senior Citizen in the electronics world. There are still a number of Trace 4048s operating in our vicinity, still going relatively strongly. In this area, there are a number of them that are about 20 years of age. ALL of them are really on borrowed time, and for the most part, not really worth repairing when problems develop, due to unavailability of parts, and the cost of round-trip shipping.
Have nothing meaningful to offer. Sometimes one can find a new, or lightly used Spare that someone kept as a backup, and then they have replaced with new model inverters, and these units can be found, sometimes at Installers or on that Auction site.
Good Luck!! Vic
how old is it?
About 18 years
That can be considered a good long life for electronics, repair may be doubtful.... consider a new inverter?
Vic said:tbear31818 said:No breaker is tripping it says it is 250 amp dc breaker no lightening strikes have the manual frustrated it goes on for hours or days then error messages won't go on then when shut down doc ond turn on sounds like shorting in inverter then eventually is will go on again
Good Luck!! Vic
Thanks to all for your help
