cooling strategies
Hi jonr,
For new construction, if one can create a Root Cellar, basement, or similar, which still has adequate access that batteries can be installer and removed, this seems the most efficient.
Personally use priority A/C in the Power Room for the benefit of batteries and electronics. It works well, but, of course, it is a large hit to overall efficiency.
Would avoid introducing humidity into the environment, however, if the batteries were in a separate room from the electronics, perhaps toying with evaporation for battery cooling might be interesting.
Need to add more PVs here, to handle more A/C for the living spaces, or perhaps Evap cooling, as the Summer humidity is generally low.
FWIW, Vic
I see tremendous successes with the root cellar type approach. But batteries in the crawl space under homes and inside the conditioned space can work well. A few customers in North Texas, Oklahoma and Kansas have combined a tornado shelter and their battery bunker.
I like the underground applications best because of the inherent efficiency. We have around 260 remote, unattended PV systems that have "buried or semi-buried" battery banks. Sizes are 7-50 KWH and some are pushing 11.5 years of operation in higher elevation/colder areas. Without fail, the cooler battery banks last much longer than the others with all else being equal.
Keep in mind that I only deal with AGM's nowadays, so ventilation requirements are fractional as compared to flooded battery designs.
Also, I understand < 1/2 of the heat production. So a much smaller ground contact area should suffice.
Most of the systems that I get involved with have the batteries racked up on shelves - two to six shelves high. With the batteries mounted on their short side, it is easy to check individual voltages, keep an eye on connections and use very little floor space.
For example, an L16 sitting on its short side is about 7" wide. Allowing for some air space between batteries, you can put a row of eight on a shelf that is about 5 feet wide. So, even a large 57 KWH bank with (24) 2v L16's, only uses a floor space of about 18" x 72" .
That's why I really like the root cellar approach.
This goes back a few years (7?) but it is a typical layout that I see from my customers (Cover removed in this picture)
http://marckurth.com/48vrack.jpg
