Battery-powered LEDs wired for 12vdc
SeanF
Registered Users Posts: 6 ✭
Hello-
I recently had to return my 12vdc LED lights due to a recall...so I had to scramble for lighting. As a temporary measure we bought Garrity brand LED touch lights, which are powered by 4 AA batteries. Using a digital voltmeter it turns out that the light is using about 5 volts from the batteries.
Radio shack sells a voltage regulator that uses up to 35vdc input and outputs 5vdc. Using my marginal soldering skills, the regulator was attached to the +/- wires that normally carry the AA battery output. Works great so far.
They've only been in service for a week, so I can't comment on the longevity of the setup. My suspicion is that the on/off push mechanism of the Chinese-made light is the weak link...but I could be wrong!
Anyway, just wanted to share. Hope this helps!
Sean
Sean
Re: Battery-powered LEDs wired for 12vdc
Sean, do you have more details on the 12 v LED lights? ie brand , format ( MR 16?) etc?
thanks,
Eric
Sure, they were 3- and 6-LED lights, manufactured by Plan 9.
More info on the recall: http://www.cpsc.gov/cpscpub/prerel/prhtml07/07258.html
HTH
Sean -
You can get twice as much light probably by just placing the two LED battery lights in series. Each will drop 6 volts vs the regulator dropping 1/2 the voltage (and costing you 50% power loss).
In any case, make sure you have a reasonable fuse (~1 amp?) in series with you wiring--just in case.
Something else you may look at - - Wal-Mart has, or at least did have here in Canada, clear LED replacement bulbs, for automotive #1156. Has 9 LEDs in it and I find it great. Designed for direct use on 12 volts. Directional light output.
Forget the current draw, 100 ma rings a bell. That would be 1/10 amp. Might also find them at other auto supply outlets.
Wayne -
Wire 2 in series with 1 regulator. Each regulator is a waste of power (as pointed out before)
You might get away with 3 in series, with some reduced light output & no regulator needed.
And watch out, if lights are on, when recharging, you have over 14V in the system then.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Cool stuff...thank you all for the feedback.
