Stepping up to 24v for next build
oil pan 4
Solar Expert Posts: 767 ✭✭✭✭
I have never messed with 24v inverters.
The largest inverter I have now is a 2000w samlex on a 13v Lithium battery.
For 24v I am thinking about getting something like the SA-2000-124, or something like it.
It has everything I need, nothing I don't.
Pure sine, 2000w running watts, 4000w surge, no transfer switch, no built in charger, it can be hard wired.
I would like to get that or something like it with a little bit higher wattage. Its over $800 so its at the top of my budget already.
The biggest baddest loads I plan to run off it are: welder, grinder, bandsaw, skill saw, small air compressor.
Its going to be part of a vehicle based 24v system, it may not even have any solar panels charging it. So the battery system draining isn't much of a concern.
What other 24v inverters out there would meet that list of criteria?
I dropped you a message, about a possible used deal...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Save up for an Outback
