it is possible to connect three string in mppt tracker
JAYMIN
Registered Users Posts: 22 ✭✭
Hello dear friends it is possible to connect three string in mppt tracker ( first two string in 1st mppt and third string in 2nd mppt ) ? if it possible then how will this two MPPT works?
There are some MPPT types of equipment (typically GT Inverters as I recall?) that have multiple MPPT inputs.
MPPT is based on input (solar array) electrical characteristics... The output (AC for GT inverters, DC current for solar/wind charge controllers) is "just a dump for energy"--And (within specifications) a "don't care" as the output is the "same" for the multiple MPPT input circuits.
MPPT is a down (or up) conversion from input to output (typically a buck converter for a solar MPPT charger that adjusts duty cycle of the buck converter to electrically "match" the input voltage/current to output voltage/current.
How to design a 2 input MPPT controller (cost effectively) GT inverter (or even solar charge controller), I don't have a clue.
Are you asking this as an installer/end user (how things work in a system)? Or are you interested as a MPPT based controller designer?
BB. said:There are some MPPT types of equipment (typically GT Inverters as I recall?) that have multiple MPPT inputs.
-Bill -
JAYMIN said:i just ask as a designer if i have a 3 string then how arrange these 3 strings into 2 mppt tracker of inverter ?
From there, ensure that the current and voltage ratings for each MPPT input is not exceeded - and you are good to go.
- 230 Forum & Website
