house bank with staeting battery hook-up
gncassie
Registered Users Posts: 3 ✭
how do I hook up my starting battery (1) with my house bank (2) all to the battery switch? All batteries are AGM. Starting is 85 ah. House is 100ah. Thanks, Jerry
Are you trying to use one battery or the other, or are you trying to use both at once?
not sure how to use this site. is this where I respond to your question. The starting battery is for starting the engine. the house bank is for use in running electronics and lights on the boat. I hope I under stood your question. Thanks, Jerry
I don't understand your question. What do you want the battery switch to accomplish? If I know what type of switch you have and what you want it to do, maybe I can tell you how to connect it.
In general, you run separate batteries so that if you run down the house battery bank, you can still start the vehicle.
There are A/B/Both battery switches (originally for boats) that do allow you to combine batteries (backup to start the motor if the vehicle battery dies, two strings of batteries so you have 1 backup if a string fails, etc.).
But if you want the engine alternator to charge both batteries, you typically get a "battery isolator" so that it charges the house battery when you drive (turns one when the ignition is on, or other options).
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=battery+isolator
There are also electronic battery controllers that "charge" when the first battery is being charged, to the second battery:
For solar, there is a simple controller that connects a set of solar panels to charge two different battery systems:SunSaver Dual Battery 25 Amp 12 Volt Solar Charge Controller With Digital Meter
And there are even more options that above... As vtMaps asks, what is it that you are trying to do? What is the size of the battery bank (volts and Amp*Hours)? What your your daily/peak loads?...
- 654 Solar Water Pumping
