48v generator
WaterWheel
WaterWheel Registered Users Posts: 388 ✭✭✭
A local solar guy is buying a load of "barely used" 3000 watt gasoline generators that put out 48v.      Version had them for emergency backup for their cell phone system and is letting them go.        The asking price will be around $500.       Assuming these generators are in great condition do you think being able to charge a 48v battery bank with a 48v generator is the way to go?     Since they are designed to charge a 48v battery I'm assuming that they put out about 54v.
48v Rolls 6CS 27P
  • m151
    m151 Registered Users Posts: 39 ✭✭
    If as described, they should be industrial quality and would be a steal! Wonder if you can get the manufacture and specs ahead of time? The average person will have no use for these.
  • WaterWheel
         We'll see what they look like but If they were industrial quality I'd expect them to burn diesel, not gas, unless they are configured to run on gas or propane.
    48v Rolls 6CS 27P
  • oil pan 4
    We are far from average.
    Average people have no means to generate any electric power on their own.
