Cleaning Solar Panels
southfork
southfork Registered Users Posts: 54 ✭✭
I've been hosing my panels off once a week to wash the dust and pollen off . Since I have a ground mount It would be easy to use a soft brush and a little soap . How often should I clean ? Also I only clean early in the morning while panels are cool .
 24 solar world 285 watt panels with 24 Enphase 250 s ground mount grid tied .
  • solar_dave
    I clean them when they look dirty.  Just a quick hose off.
  • vtmaps
    I use only distilled water and no brush
    southfork said:
    How often should I clean?
    Whenever it rains B)
  • Johann
    Johann Solar Expert Posts: 245 ✭✭✭
    I clean mine about 2 times a year, one time in the spring when the pollen is heavy and no rain and one time in the fall after the leaves fell off the trees.
    I clean as needed, and right now the Pine Pollen is coming on heavy.... so once a week unless it rains...
  • South Africa
    South Africa Solar Expert Posts: 295 ✭✭✭
    I check the power they produce, if below expectations, I wash them.
    Otherwise I also use distilled water, no brush.
    5kVA Victron Multiplus II, 5.2kW array, 14kWh DIYLifepo4 bank, all grid-tied.
    I hose them off early AM, while still wet from overnight dew.
  • optiononesolar
    optiononesolar Registered Users Posts: 1
    Solar panels are self cleaning, unless you’re panel is minimally tilted or very dry. Using your soft brush and hose will do!
    Dave Angelini Solar Expert Posts: 7,025 ✭✭✭✭✭✭
    Birds of prey are an issue sometimes up here. Those splats can be just in the right place!
