105ah on 90w pannels
henna
Registered Users Posts: 3 ✭
hi guys im new to the forum. im from south afica looking for some basic advice.
story goes as such, i love going camping and always been a minimalist, never needed much, but now i have problems, #1 the missus, i need some sort of lighting and #2 i run a small bass boat on a 30lb trolling motor. so my two 105ah batts are taking a beating.
so what i want to find out, will i be able to recharge 80% of a 105ah with 7-8 hours of good sun (rotating the angle) with a 90w pannel. rotating the batts with weaker one running two 5w leds at night for 4 hours max.
Please forgive my ignorance if im way of
hope to hear from someone more experienced.
Welkom Henna, jy is by die regte plek. Die forum mense hier verstaan solar sisteme.
Translated: Welcome Henna, you have come to the right place. These forum users really understand solar.
5kVA Victron Multiplus II, 5.2kW array, 14kWh DIYLifepo4 bank, all grid-tied. -
To charge 1 x 105ah battery, you need at least 5% - 13% of the AH to charge it properly.
So min +-5.25amps to max 13.65amps.
You have 2 batteries, assuming 12v, so it is 210ah, so is 10.5amps, max 27.3amps.
You are using it during the day, want lights at night, so you have to go for max charging of 27.3amps
A 90w panel is completely insufficient. Sorry.5kVA Victron Multiplus II, 5.2kW array, 14kWh DIYLifepo4 bank, all grid-tied. -
south africa thanx for the reply, im only looking at charging the one battery for use on the boat. the secondary one wil only be used for minimal lighting
The Stecca, for one battery only, will work, at max capability. If I was you, I would go for a Victron 75/15 or 75/30 charge controller, because once this gogga bites, you are going to want to do more i.e. why only use it for camping? At home, run your alarm system from the system 24/7, use it as a backup for lights with power failures. Just get a 350va small 12v inverter for powering your TV?
For IF I understood BB's teachings right, You will need:
+-96watt array, to charge at 5%, which is good for weekend use.
192watt array to charge at a 10% rate - good for daily charges.
250watt array to charge at 13%, - which, if it was me, I would have gone for, mounting on the bass boat for shade, and a portable frame for at the camp site.
The above takes into account 1 day spare, 50% DOD, 77% system efficiency, so you will have ample power.5kVA Victron Multiplus II, 5.2kW array, 14kWh DIYLifepo4 bank, all grid-tied. -
you could also directly hook up a smaller (90W) panel on the boat without a controller to boost the power used when using the trolling motor, ie supplement the battery and recharge it a bit while casting.. it can add a few hours a day of electrifying trolling before the gas is used... I frequently re-aimed the panel towards the sun for max output in my cartopper 12 footer
hth
If you are trying to squeeze the most of a few panels you have to get a real MPPT charge controller.
Even rotating a panel to get 7-8 hours of sun, will require 2 days to harvest that much, Only about 5-6 hours of good sun in the very best locations, Morning and afternoon sun has less power because of all the atmosphere it has to pass through,
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
