PV inverter and MPPT feeding from same PV array?
Can I connect a PV Inverter from the same PV Array of my MPPT Charge Controller to take advantage of the full potencial of the PV array when the battery are charged by the MPPT?
I have a MX60 charging 8 Trojan batteries with 4 x 250 Watts panels but when the batteries are full the MX60 goes sleeping and I waste the rest of the energy in that day. so I'm thinking to install a Enphase M250 to each panel to AC couple to the output of my Inverter/charger.
This way I do not use the reserve from my batteries just the exceed of my PV array.
Theoretically it does not have anything in common because the inverter connected to the batteries has a magnetic bond to the AC output and the PV inverter will have a AC Coupling will not notice that...
Am I right?
    I guess you plan to split the out put cables? Sounds "Wacko"
    Generally a charge controller will draw current from the array once in float to maintain the float voltage. So just save your money!
    If you do not want to WASTE some of the PV  production in an OFF GRID system, the only way to do it i to turn something ON
  • vtmaps
    Your scheme won't work, but your desire to capture the unharvested, potential energy makes sense.  There are several ways to do it, but most of them work best with a resistive load... the amount of "wasted" energy changes minute by minute.
    You can accomplish your goal with another controller used as a dump controller.  Set your MX to charge at 0.2 volts higher than the dump controller.  The MX will put out all it can to raise the voltage above what the dump controller allows.  The dump controller is where you set your desired absorb and float voltage.
    The Midnite Classic controller has a sophisticated feature called "waste not"... an auxiliary output that can control an SCR.  You can read lots about it on the Midnite website and their forum.
    What does that accomplish vtMaps? He's not talking about running a specific load only when the charge controller is in float.
    To use the energy from the array all he needs to do is run loads, or as Westbrach said, "turn something ON".
    Dave Angelini Solar Expert Posts: 6,750 ✭✭✭✭✭✭
    Almost any charge controllers can Aux control a load. Your scheme does sound weird to me because of what others have said.
    Your goal is a good one and I think I have tried them all. At this point in my offgrid life I think the mini-split heat pump is the best way to use excess energy. I have given up on AUX relays and do this all with wifi directly controlling the load for my clients.
     You really have to also keep in mind that all of this excess capacity off grid will be needed in six months or so when
    when the sun is not so high in the sky. It is this balance (off too much and too little) that you just have to accept. It is also the principal I use for many of my clients who choose not to run a generator.
    You said the MX-60 is sleeping, it is floating really is it not?
