HELP SETTING UP ANOTHER SOLAR SYSTEM
justinlee
Registered Users Posts: 53 ✭✭
Thanks for all the help on my main system we have been talking about for almost three weeks...I have learned a whole lot of good and important information from you guys and I appreciate it. So besides the cabin I have out in Oklahoma I also have my travel trailer out there on a different part of my property. I had this previous equipment on my old system and I want to see if it will do the stand alone job for the travel trailer that may only be occupied now 2 to 3 days at a time every two weeks or so....these are my sharp 230 watt 24 volt panels I mentioned in my previous thread..they are
Maximum Power (Pmax)*: 230 Watt
Tolerance of Pmax: +10%/-5%
Type of Cell: Polycrystalline silicon
Cell Configuration: 60 in series
Open Circuit Voltage (Voc): 37.1 Volts
Maximum Power Voltage (Vpm): 30.0 Volts
Short Circuit Current (Isc): 8.48 Amps
Maximum Power Current (Ipm): 7.67 Amps
Module Efficiency (%): 14.10%
Maximum System (DC) Voltage: 600 Volts
Series Fuse Rating: 15 Amps
CC is
I remember us talking about the vmp on these panels may not be enough to get a proper charge .....Is there a way this equipment I have listed here could work for me in this configuration with my travel trailer?
thanks Justin
CC is
XANTREX C35 CHARGE CONTROLLER 35A, 12 OR 24V (PWM)
STRING OF 4 6V WIRED TO MAKE 24@450AHI remember us talking about the vmp on these panels may not be enough to get a proper charge .....Is there a way this equipment I have listed here could work for me in this configuration with my travel trailer?
thanks Justin
sorry forgot ...2 of these sharp panels
Vmp~30 volt panels will not work well with a 12 volt battery bank and PWM controller. 2x panels in parallel will only have ~1/2 of the Wattage into the battery bank. It will work (but 1/2 panel efficiency).
And 2x in parallel will not fully/quickly recharge a 24 volt battery bank (on PWM or MPPT).
There is a small "boost" type MPPT charge controller from Genasun, but it is too small to be useful with these panels/battery bank.
So, that leaves you with two "viable" options. Both require a more expensive MPPT type charge controller.
First is run a 12 volt battery bank and run the two panels in parallel behind a MPPT controller.
Or run the two panels in series with a MPPT charge controller. Most efficiently would be to charge a 24 volt battery bank. But it will work with charging a 12 volt batter bank too (an MPPT charage controller will run a bit "hotter" or less efficient).
- 234 Forum & Website
