Mega power Batteries.
Johann
Solar Expert Posts: 245 ✭✭✭
Does anyone know what kind of battery that might be and would it be good for solar?
MP 12750 12v 75 Ah
Boost / Equalize voltage 14.5V - 15.0V
Float voltage 13.5V - 13.8V
Max charging amps 22.5A
Amp hour 75Ahr.
It also says.......Valve regulated lead acid rechargeable battery
Dist. by Mega-Power Batteries
Greensville SC
I am wondering if this is just like a regular sealed deep cycle or AGM Battery etc etc.
What would be a average age they could get.
I guess the charging and discharging amps should be about the same? as guide line since it shows only MAX charging current.
I tried to google that MP 12750 battery, but I only get results for a power sonic PS 12750 battery for some reason.
I kinda inherit 10 of those batteries, which 9 of those batteries still showing a voltage of 12.7 to 12. 9 volts sitting here at the house for 2 days now without any charge and without any load........and 1 battery has 8.6 volts which may be a bad battery.
MP 12750 12v 75 Ah
Amp hour 75Ahr.
Greensville SC
Aguarancher said:here you go.. http://www.mega-powerbattery.com/commerce.cgi?cart_id=1461192904.285&product=12-Volt&pid=50&keywords=
Thanks for the link,
I have been on that website, but they do not mention the same battery that I like to have the info on. The battery they mention is a PS 12750 battery.....the battery in question is a MP 12750 battery. I could not find no data or spec sheets yet. Makes me wonder........
I even send them a e-mail and ask the question, but no answer so far and no e-mail at this time.
Thank you for trying to help me.
