Line side tap meter adapter
bill von novak
Solar Expert Posts: 891 ✭✭✭✭
I just saw this adapter on a nearby home with a solar installation and thought it was a pretty elegant solution to the requirement for a line-side tap. I hadn't seen one of these before.
That is interesting, did you get a manufacturer or part number?
No, I didn't want to go into the guy's yard.
It looks to me like the setup that most utilities allow for connecting a standby generator. Unfortunately the local utility in NH, Eversource doesn't allow them (while some Vermont utilities offer to install them.
The ones (one) I have seen for generators will disconnect the home from the utility feed and connect to the genset when the genset plug is inserted (as I recall). This one does not appear to do that (hardwired to GT inverter?).
Here is a different brand/implementation. Costs ~$400 (retail).
http://connectder.com/wp-content/uploads/2015/07/SIMPLE-ConnectDER-cutsheet.pdf
http://connectder.com/products
http://www.homepower.com/articles/solar-electricity/design-installation/methods-streamlined-supply-side-interconnection
That is a two pole breaker under that access panel. It appears that this can do either a line side or meter side tap.
- 231 Forum & Website
