New forum software is live - report any errors, bugs, or issues here.
While we're doing feature requests...
please fix your email notification system. I would like to get one email when there have been new postings to a thread that I subscribe to. I have email notification turned off now because I was getting an email for EACH new posting... I only need one email to tell me to check on a particular thread.
I've seen that on other forums, yes. You don't get another email until you visit that thread again.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
I have sent that email notification request to our support person.
Along with improved editor (theme changes are also our responsibility. ... additional costs).
Interesting, here at work the WYSIWYG buttons all appear to be blank, as I mentioned in an earlier post. But that is not why I popped in here. I think I found bugs that are related.
When you hover over the date of each post (just below the poster's name) you can see it is supposed to allow you to link directly to that post. That link for the first post in a thread is formatted differently from all the rest. It would appear that if you click on the link on the first post it should take you to the beginning of the thread (the first post). But it doesn't, it takes you to the bottom of the last page. Next, if you hover over the link at the bottom of the page to go to page 1, the link is formatted almost the same, but it adds "/p1" to the end. For me, that takes me to the bottom of the first page and not the top. So I don't see any way to link to the top of the first page. Finally, if you hover over the link for any other post on the page the link is formatted differently and would appear to let you link directly to that comment. For me, sometimes it does, sometimes it jumps to the bottom.
4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Vanilla uses AJAX.googleapis.com (and perhaps solar-electric.com) for browser scripting. If you have AJAX blocked (noscript) or turned on scripting in the browser, some of this stuff may not work.
Regarding linking, for example this thread, the page #1 points here:
http://forum.solar-electric.com/discussion/349832/new-forum-software-is-live-report-any-errors-bugs-or-issues-here/p1
And takes me to the top of the page... But does not for you?
Bill, I have noticed a bug just now...
I quoted a previous post and started to add my comment , outside the Quote area. I made a typo and when I removed it I could no longer type in the external area , but my comment was showing up INSIDE the Quote area. I had to back out and restart the whole process..
Hope this is fixable, It is a bit hard to discern what is a quote and what is new comment as some add below and others above the Quote...
westbranch said:I quoted a previous post and started to add my comment , outside the Quote area. I made a typo and when I removed it I could no longer type in the external area , but my comment was showing up INSIDE the Quote area. I had to back out and restart the whole process..
Yea.... I have written a long missive to our support person that, in the end, all "we" see is what is on our screen. The under-laying database, the neat method of them hosting forums on their servers (NAWS does not need to do server maintenance now), etc. is all very nice--But, in the end, what is on the screen (tools, editors, formatting, etc.) is what people are going to make their judgments on.
An upgraded editor--I am really pushing for that. Probably will not happen "soon" (more than a few months, at least).
Haven’t been on for some time (busy at work), but upon our return, we notice a couple of issues:1. Our use name (which has an “&” in it) really gives the forum software heartburn2. Attached images in our posts don’t seem to render any more. It appears that all the images have been moved off-site to rackspace’s CDN, and are no longer at the old URLs.3. Whenever we type anything in a text box post (even using the arrow keys), it scrolls to the top of the page. Only return doesn’t do this. Very annoying.
4. Signatures seem to be gone, too. Does this need to be re-entered?—David & LauraHouse: 2x SMA SI 6048 w 24x 2V DEKA Unigy II; 2x SMA SB 3000TL-US w 24x Sharp ND-H235Q2
Cabin: 1x Magnum MS4024 w 24x 2V DEKA Unigy II; 1x Morningstar TS-MPPT-60 w 6x Sharp ND-H235Q2; 1x 200 Watt Harris microhydro
Intertie: 1x SMA WB 3800; 1x Lambda GEN-600 DC Supply; 2x PSL pQube -
If you are using something like Stop Script, you need to allow scripts from solar-electric.com and ajax.googleapis.com
Signatures need to be added via the edit profile/signatures ("gear" upper right):
http://forum.solar-electric.com/profile/signature
And for problem about photographs, if you can post a link to a post or comment, I can have them look at it.
Lastly, for your user name, I will ask our guy to look at it... I am not sure if they can fix the software or it will need to become David and Laura (or similar) instead...
PS: I guess you may have problems doing your signature until the "fix" is done to your name (I cannot access your profile easily--I will not try and hack my way in--And possibly mess-up the database).
No script blockers running, so that’s not the cause. I'll just write my posts in a text editor, and paste them in for now, until I figure out what triggers it.
It looks like I can re-add my old signature, so I'll do that shortly.
An example of a thread where the photographs are messed up is http://forum.solar-electric.com/discussion/24155/gulf-island-off-grid-system-part-6-solar-expansion-intertie
I may be able to fix them manually by updating the URLs to point to rackspace manually.
As for the user name, it seems to just prevent me from displaying my main user page, so right now, no need to change the account name.
Thanks for the response!
The forum software is still having problems with the &, so I think to support folks are going to have to change it to "David and Laura"... If your login fails at some point, try that instead.
If things change otherwise, I will use your email address to notify you of the new login ID.
David, your ID is now "David and Laura".
And we can now access our user profile page.
Thank you!House: 2x SMA SI 6048 w 24x 2V DEKA Unigy II; 2x SMA SB 3000TL-US w 24x Sharp ND-H235Q2
Bill, every time I click on this thread it only takes me to the first post even though I have looked at it many times, last time was yesterday I think...?? A bug?
I don't have that issue. I usually right click and open in a new tab, and this one opened right to the last post today. Win10 / ChromeNorthern NM, 624 watts PV, The Kid CC, GC-2 batteries @ 24 VDC, Outback VFX3524M -
Westbranch, this is the link I use to get to the end of thread:
http://forum.solar-electric.com/discussion/349832/new-forum-software-is-live-report-any-errors-bugs-or-issues-here#latest
Over the last few days, anyone seeing:
1. login "lost"
2. clicking on link takes you to "older posts" (not always to beginning of thread like Westbranch)
I have seen this both on desktop and Android phone.
Bill I should have added that it happens when using the "Recent Discussions " button to see what is new, and it hows up as new for me... I'll try to remember all key strokes next time...
FWIW,
This Thread is out of chronological order, the way I see it, and by the way that I accessed it:
Posts from 1/14, followed three posts from 1/13, then two posts from 1/15, and then, five posts from 1/13, followed by two more posts from 1/15 ... makes this thread IMPOSSIBLE to follow, and because the time that previous day's posts are DELETED by Vanilla, one cannot even tell if the chronology within a single noted date is correct.
Are we going in reverse, now? ... Vic, where it is still today -- 1/15/16
Thank you Vic,
Something is definitely broken. I have submitted a bug report.
Bill, that starting a t the first post just happened to me on
http://forum.solar-electric.com/discussion/350234/new-system-install-outback-gs8048-final-items-before-startup#latest
It is happening to me too... And the problems in this thread are repeatable. Hopefully, it will be easy for our support folks to find and fix.
Great, I thought it might just be me on a Snowy Sat morning...
Bil, looks like there is a double post here, just that Resthome made a typo correction in the last line...
http://forum.solar-electric.com/discussion/350138/minimum-load-xantrex-prowatt-sw-2000#latest
Thank you Eric. Fixed.
BB. said:Thank you Vic,
Hi Bill, as usual Thank You very much for all of your time and effort for the benefit of the community. VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
My pleasure Vic.
Bill, last post with picture of re-setable CB in http://forum.solar-electric.com/discussion/24929/fuse-between-inverter-and-load#latest
is where it is taking me to every time now.... something to do with the attachment?
EJ
BB. said:Vanilla uses AJAX.googleapis.com (and perhaps solar-electric.com) for browser scripting. If you have AJAX blocked (noscript) or turned on scripting in the browser, some of this stuff may not work.
As I noted, sometimes I go to the top, sometimes the bottom. At this point the link you posted took me to the top.
I was logged off, which you asked about.
Typing in this text box has a lag if I type too fast.
As someone else noticed, embedded images in posts are now broken. Example: http://forum.solar-electric.com/discussion/comment/157599/#Comment_1575994.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
OK, got one answer here (I think). The "Out of Order" discussions and the positioning at the "wrong place" in a thread (not, apparently at the next unread post).
It turns out this is a "feature" of the software, I think, when somebody "promotes" a post--It becomes a "Best Answer" post. Then all "best answer posts" are now moved to the "front of the thread" and all "normal posts" are posted later in the thread.
And, this (as far as I can tell), means your "next unread" post can be "in the middle" of the discussion, or at the end of the thread, depending if the next unread post is is a "promoted post" or not.
Unless some folks here disagree with me, I have requested that this whole "best answer"/post sorting function either a), not change sorting order (the forum theme can "highlight" promoted answers--But I really don't care either way), or b) turn off "promoting" completely to stop this "out of order sorting". My belief is that this out of order sorting just "kills" discussions (very confusing at to what you questions/answers you have a comment about).
- 616 Discussion Forums/Café
