Opportunistic load ?
Arkansasoffgrid
Solar Expert Posts: 117 ✭✭
What's the general consensus of running a crockpot during daytime hours, say 9am-3pm on a timer. We're generally in float mode by 11am-12, so this could be a win-win if it's plausible.
8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
I used to run a breadmaker on sunny afternoons, so the crockpot should not be a problem. Drain is actually not that bad for one of those once they reach temperature.Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
It's all fine provided you can "trust" the weather in your area. I was long toying with the idea of using surplus energy to heat water but realized that unless the system could automatically switch on and off according to battery voltage I'd be taking a big chance if it were to suddenly turn cloudy whilst I was away...
Why not just hook a water heater element to the input power?
That way if it clouds over worse case the batteries just don't get charged.
I have a tankless propane water heater. Figured to use "excess" power to cook a meal while we're at work8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
