What is proper dod at -1c
just starting
just starting Registered Users Posts: 235 ✭✭✭
I have 6 250w panels a 60-150 894ah agm bank its staying between -3 and 1 c and in the morning the Volts on the cc say 25.2 on avg and once 25 v am I OK
200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024  - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher  Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
  • just starting
    Also I built a insulated box that has r 13 fiberglass and 2" foam in the box I can run some PVC and a small 24 v fan would it be worth heating up the battery's for power gain
  • zoneblue
    We dont get those sort of temps here, but as far as i know thats not too cold for a charged lead bank.  25V is fine. 24V then youre low.
  • inetdog
    Be careful how you interpret the voltages you read on the CC, especially if the CC has a remote temperature sensor for battery temperature.
    The charging settings need to be adjusted to match the actual battery temperature, but some CC manufacturers have chosen (to avoid confusing casual users?) to display the "corrected" measured voltage rather than displaying the real voltage and changing the set points.
    SMA SB 3000, old BP panels.
  • just starting
    It does have a temp sensor my cc is a xantrex 60-150 mppt I'll check with a volt meter
  • CALLD
    CALLD Solar Expert Posts: 230 ✭✭
    25v under load indicates a high state of charge (above 80% SOC), 25v resting voltage indicates a partial state of charge. A fully charged AGM battery (at rest) should read closer to 26v even at a temp of -1°C
  • softdown
    softdown Solar Expert Posts: 4,054 ✭✭✭✭
    Surprised that this question has been unanswered by the more knowledgeable here. I don't think heating them is a good idea unless you can do it with the sun....which would produce warm daytime batteries and cold night time batteries. Batteries last a lot longer when they are kept in a cool environment. Canadians may think they are better at battery management because their batteries last longer up north.
  • just starting
    At 3 am my bank is at -6c and 24.7 underload I will shutoff inverter for a few hours and check bat voltage
  • just starting
    Thanks for the responses
