DIY Solar Panels for kids
Not sure what you're looking for...
Building solar panels involves soldering, I wouldn't recommend for a 4th grader.If it's to demonstrate solar, you could, pickup a small panel and some NiMH or NiCD batteries to charge and some cheap electronic gadgets. I did this for my nephew. just used bolts for terminals, dollar store fans, and short string of LED 'Christmas lights that ran off battery pack...
If it is indeed building solar panels, I would suggest getting some 'tabbed' solar cells these will already have the thin tinned leads soldered to the back of the cells. They can be found on eBay or Amazon. For a small demonstration project, I might suggest creating a 5 volt charging station and again use 4 NiCD or NiMH batteries. Many things run on 5 volt USB these days and you can butcher an old tower for a panel type usb outlet.
The "typical" large diameter "raw" solar cells from E-Bay are very fragile. If you know what you are doing, it is possible to connect a few "pre-tabbed" cells together--Otherwise, they are very thin and easy to break just separating a single cell out out of the package.
http://www.ebay.com/bhp/tabbed-solar-cells
Soldering together raw solar cells that are more fragile than a potato chip with a 700'F soldering pen and lead solder.
I started soldering when I was in 5th grade, only burned my self good once. Then you learn.
You can get a small solar panel with a clip line for around $20 on amazon, if that's what you're looking for.
Thanks to everyone. I'd be supervising my son throughout the whole project and I guess he we would be somewhat happy with the soldering. Just gonna do that part for him though just to be sure.
