Hypothetical question
Hi all
My question is in regards to measuring the voltage at a battery bank.
If you have a bank of 4 batteries, will they act as a single entity when it comes to measurement?
How do you measure the volt, i thought by putting a meter on the last battery terminals would give an overall voltage for the whole 4?
Any ideas on this would be great.
Don
Don
Re: Hypothetical question
Are your batteries wired in series or parrallel?
You can measure voltage of any single battery at it's own + and - terminals,
or,
at the + and - ends of a series wired set.
If batteries are wired in parrallel, measuring at the + and - will give you the entire bank voltage.
Wind and Sun has a great battery info page;
http://www.windsun.com/Batteries/Battery_FAQ.htm#Battery%20Charging
