Formulas for off grid solar systems
Morningstar charge controller, 1000W Samlex inverter. I would like to upgrade my system to accommodate 3000wh.
Formula sizing, panels, charge controller, inverter, and batteries? Had them at one time, however computer crashed, had to format disk.
Would like to thank all in advance!!
Just give us all your money!
Ooops rather give us all your information.
Load 3000wh? Load during the year (winters in northern hemisphere have less sun and often larger loads... then again if you run an AC in the summer time and heat with wood...)
Days of autonomy(how many days of no sun do you want to withstand with out running a generator)
Time of day of your loads?
Will you have an alternation energy source?
Direction of solar array, will it be shaded at any time?
Location, where on the earth are you?
Do you need a larger inverter?
etc...
Having experience with your current system puts you in a pretty good place to know how well solar performs at your location, azimith . I find i can simply the math for a given location, by figuring out the Wh/d per Wp ratio from practice. In other words if you have 1000W solar, and it consistently produces 2kWh/day then that figure is equal to 2. Thus to scle up to 3kWh/d you need 3kWh/d /2= 1500W solar. Etc.
For the battery you want to aim for a 0.1C charge rate, and a 0.25C discharge rate. That combined with the forum rule of thumb reratings:
PV+CC 0.77
Inverter 0.85
Battery 0.8
Gets you pretty much everything you need.
Thanks a lot Zoneblue, really appreciate your help!!! God bless you!
Sorry you don't appreciate my help!
For others, truly all off grid solar installations are different. One size does not fit all. Rules of thumb can get you in a lot of trouble. better to talk out your whole situation....
Thanks Photowhit for all your help! God Bless You!
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
