Inverter Purchase Advice Request
marsofold
Solar Expert Posts: 45 ✭✭
I just bought four Trojan L16RE-B 370AH batteries from our host. Now I want to buy an inverter that can meet the following specs: can output 2000 watts continuously, able to surge for 200 milliseconds at 4800 watts (well pump), able to run with battery voltages up 15.9 volts (equalization). Would prefer 12 volt operation, but willing to do 24 volts. Under $2000 would be a bonus (my current inverter is a Xantrex PROwatt SW2000 that I paid all of $375 for). And it's got to be reliable enough that no websites are offering refurbished units for sale. So far the ONLY inverter I've found meeting all of the above is an Outback FX2524T for $1633(arrrgh!). If I have to get a Mate, then that's another $214, for a total of $1847. So I'm asking: #1 is there a cheaper alternative that meets ALL of the earlier specs, and if not,then #2 Do I really need the Mate if all I want to do is charge my batteries from my panels, run my loads, occasionally equalize, and in winter charge from the power line/generator? Would the default settings allow this without buying a Mate? Thanks for all and any suggestions...
Well for that you might consider looking at a ~ 3000W rated inverter and using 24 V minimum, you do not want to run inverters and other electronics at max rated output, think about race cars and how often they rebuild an engine ~ once per race...
With inverters you get what you pay for. So FX is a good choice. Regarding the mate, you dont need a mate unless:
- you want controll over sleep mode
- you want controll over charging modes.
- need to stack
- etc
Another approach to the well pump is to replace it with something with lower surge rating. There are some quite groovy pumps available now. And that approach might be cheaper than buying a highspec inverter that isnt needed for much else... maybe.
OK, kicking and screaming I bit the bullet and after shipping spent $1899.70 on an FX2524T & Mate from our host (solar-electric). No doubt I'm gonna have questions when I install it. Glad to have this forum...
- 230 Forum & Website
