Wiki relates NaCl stores 259 kwh/m3
Re: Wiki relates NaCl stores 259 kwh/m3Hi at all!
Wiki page(NaCl) relates NaCl stores 259 kwh/m3!
Is it possible?...
in english please. Sounds like you have a mouthful of hot salt .Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thermal storage of a cubic meter of salt .... -
"Sounds like you have a mouthful of hot salt ."
hey mike, it seems you weren't that far off.:roll: -
I knew the gist of it, but haden't decoded the cubic meter part.
Any ideas of what the storage capacity of water/ice is ? It's at the colder end of usefulness, but some time shift air conditioning schemes use it.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 234 Forum & Website
