Xantrex Gateway and yahoo widget
Kefalonianman
Solar Expert Posts: 60 ✭✭✭✭
hope someone can help i have the xantrex gateway and i have lost the widget file, i have looked everywhere on the internet and cannot find a download can anyone please send me a link or download to the file.
thank you
thank you
Wow. I have the installed widget, but I don't know where the installer CD is. Compared to the Combox I also have, the gateway is not nearly as useful.
i'll look around, but don't hold your breathPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I found the widget here a couple years ago, the download link still works today
http://updates.clipsal.com/downloads/software/xantrex/Xantrex_Widget.zip 334Kb
other discussion here:
http://forum.solar-electric.com/forum/solar-electric-power-wind-power-balance-of-system/advanced-solar-electric-technical-forum/20102-xantrex-gateway-setup
From Schnider FAQ:
Resolution:
Perform an internet search for 'Yahoo Widgets 4.5.2' Download from well-reputed third-party download websites.
Cause:
Yahoo Widget Engine is no longer supported by Yahoo. Existing widgets such as the Xantrex/Schneider Solar Monitor Widget continue to function.
