Magnum Automatic Generator Start
tnhunter
Registered Users Posts: 13 ✭
Can the Magnum ME-ags be used with a 48 volt battery bank system for backup generator starting? All I have read from the owners manual is 24 volts maximum.
Re: Magnum Automatic Generator Start
yes it can its just that they just built there firs 48 volt unit so they havent redone all the literature -
Perfect timing !
The 48 Volt version is "just out"
boB -
That is great news!!
Another question, the operator manual on page 8, figure 4 shows a Gen Hour meter connecting to pin 2 on the controller. If the genset does NOT have an hour meter, does this connection have to be made to operate correctly or do I need to put an hour meter on my Genset?
- 228 Forum & Website
- 618 Discussion Forums/Café
