Production down from summer heat?
gtojohn
gtojohn Registered Users Posts: 20 ✭✭
I have a small 6 panel 1.4 kw array with enphase m215 inverters. Its only been in use since May. We've had a mild summer but in the last week we started hitting triple digits here. Previous month I'd average 9-9.6kwh a day. This past week I'm getting closer to 8.0. Could this be the heat causing inverters or panels to clip? I don't have the envoy, just monitoring with a stand alone induction style power monitor. Need to get my ladder back from a neighbor to check panels for bird poop.
  • solar_dave
    Yeah it happens every year at this time here, production slides due to heat.
    Probably... You can get a ~3% drop as new panels "age/burn in" during the first 6 months.Another 10% drop due to high temperatures (and dust/bird droppings) is certainly possible.
    A couple weeks ago, I was down 30% from nameplate, from +100F heat and no breeze, but they are cranking today
  • SolarPowered
    SolarPowered Solar Expert Posts: 626 ✭✭✭
    If you have a mono panel there will be a significant loss in power due to the heat.
    Polys tend to hold up a little better to heat.
    95* weather it is common to see a 2.5% drop in peak power, roughly 1.25% from the solar panels and 1.25% from micro inverter.
    If you have soiling from not cleaning the panels for 3 months "minimum" that is roughly another 2.5% drop.
    System performance could be affected by up to 5% ptc which could have the system harvesting between 98%~101%, monthly harvest.
    Half of the systems I am monitoring in California due to the drought (soiling), and the heat wave is causing the systems to operate between 93% and 98% daily, which is normal under PTC.
  • gtojohn
    Probably more the heat, its been over a hundred with no wind. I gave them a good wash. Despite heavy rains in June my panels had a thin layer of dust, tree sap and bird poop. Windex dried before I could wipe them clean. I ended up using a 1 gallon sprayer and a mop. I'm considering next time using something like prestone bug and tar windshield cleaner. Any other recommendations on cleaning?
  • SolarPowered
    gtojohn wrote: »
    Do not use detergents on panels if you have A/R coating.
    It should be as simple as just using a micro fiber sponge and a bucket of water, do not use a pressure washer as it can blow out the seals to the frames.
  • verdigo
    verdigo Solar Expert Posts: 428 ✭✭
    My summer production has fallen off as well. Humidity (more haze) makes a  big difference vs low humidity days. Overall my net production is better in summer but I do better on a clear winter day even with shorter hours than a clear but otherwise hazy day.
  • inetdog
    And do not apply cold water to hot frames. Clean first thing in the morning or late in the evening.
    SMA SB 3000, old BP panels.
