Interesting Combo Product
ZoNiE
Solar Expert Posts: 100 ✭✭
I saw an interesting product at the intersolar show this year. The R-Volt, Basically a PV panel with an air box beneath to draw heat off the surface which cools the panel and helps heat the house in the winter... Cool Idea, I was thinking of something like this to feed the warmed air into the evaporator box on my roof mounted Packaged Heat pumps...
http://www.systovi.com
Thanks ! Nice. Much nicer if it was in a yard on a pergola instead of holes in the roof of a house."we go where power lines don't" Sierra Nevada mountain area
Yeah that design won't go far. Its been done before. The heating efficiency for the home is lacking......Significantly..... It will also draw in humidity without a dehumdifying filter system, during the winter. Its escalated costs, with no significant return, initial production costs are higher.
So you don't have any in return profit ?
Basically.... It will eat up the 30% tax credit, so the 30% means nothing.
It drifts further away from grid parity rather than bringing it closer.
Has this concept been applied to water heating/solar panel cooling? Heating water will be much more effective as far as heat transfer, but maybe more difficult? Combine this with absorptive refrigeration - might be the "two birds with one stone" solution to true air conditioning??3850 watts - 14 - 275SW SolarWorld Panels, 4000 TL-US SMA Sunny Boy Grid tied inverter. 2760 Watts - 8 - 345XL Solar World Panels, 3000 TL-US SMA Sunny Boy GT inverter. 3000 watts SMA/SPS power. PV "switchable" to MidNite Classic 250ks based charging of Golf cart + spare battery array of 8 - 155 AH 12V Trojans with an APC SMT3000 - 48 volt DC=>120 Volt AC inverter for emergency off-grid. Also, "PriUPS" backup generator with APC SURT6000/SURT003 => 192 volt DC/240 volt split phase AC inverter.
Sundrum, I think, is still around:
http://www.sundrumsolar.com/products--services.html
Here is a bit of discussion here:
http://forum.solar-electric.com/forum/solar-electric-power-wind-power-balance-of-system/general-solar-power-topics/3976-possible-hybrid-pv-hot-water-panel-product
You can find some other discussions by searching Google ("site:" tag limits searches to a specific website):- sundrum site:forum.solar-electric.com
