Interesting Combo Product
ZoNiE
ZoNiE Solar Expert Posts: 100 ✭✭
I saw an interesting product at the intersolar show this year. The R-Volt, Basically a PV panel with an air box beneath to draw heat off the surface which cools the panel and helps heat the house in the winter... Cool Idea, I was thinking of something like this to feed the warmed air into the evaporator box on my roof mounted Packaged Heat pumps...
http://www.systovi.com
  • Dave Angelini
    Dave Angelini Solar Expert Posts: 7,115 ✭✭✭✭✭✭
    Thanks ! Nice. Much nicer if it was in a yard on a pergola instead of holes in the roof of a house.
    E-mail offgridsolar@sti.net
  • SolarPowered
    SolarPowered Solar Expert Posts: 626 ✭✭✭
    Yeah that design won't go far. Its been done before. The heating efficiency for the home is lacking......Significantly..... It will also draw in humidity without a dehumdifying filter system, during the winter. Its escalated costs, with no significant return, initial production costs are higher.
  • tupule
    tupule Banned Posts: 2
    So you don't have any in return profit ?
  • SolarPowered
    tupule wrote: »
    Basically.... It will eat up the 30% tax credit, so the 30% means nothing.
    It drifts further away from grid parity rather than bringing it closer.
  • MarkC
    MarkC Solar Expert Posts: 212 ✭✭✭
    Has this concept been applied to water heating/solar panel cooling? Heating water will be much more effective as far as heat transfer, but maybe more difficult? Combine this with absorptive refrigeration - might be the "two birds with one stone" solution to true air conditioning??
    3850 watts - 14 - 275SW SolarWorld Panels, 4000 TL-US SMA Sunny Boy Grid tied inverter.  2760 Watts - 8 - 345XL Solar World Panels, 3000 TL-US SMA Sunny Boy GT inverter.   3000 watts SMA/SPS power.  PV "switchable" to MidNite Classic 250ks based charging of Golf cart + spare battery array of 8 - 155 AH 12V Trojans with an  APC SMT3000 - 48 volt DC=>120 Volt AC inverter for emergency off-grid.   Also, "PriUPS" backup generator with APC SURT6000/SURT003  => 192 volt DC/240 volt split phase AC inverter.
    Sundrum, I think, is still around:
    http://www.sundrumsolar.com/products--services.html
    Here is a bit of discussion here:
    http://forum.solar-electric.com/forum/solar-electric-power-wind-power-balance-of-system/general-solar-power-topics/3976-possible-hybrid-pv-hot-water-panel-product
    You can find some other discussions by searching Google ("site:" tag limits searches to a specific website):
    • sundrum site:forum.solar-electric.com
