Aging battery bank - What happens when sulfation doesn't kill a battery bank?
After enough plate material falls and fills the sump at the bottom the the battery, one cell will get shorted out from the debris. You might be able to shake, rinse and flush the debris out, but damage has been done, and material lost off the plates.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
This is something I've often wondered about.... A sump must be deep enough to hold all that debris, but doesn't a deep sump become a place where concentrated sulfuric acid becomes sequestered? As normal stratification occurs, concentrated sulfuric acid will settle into the sump. The gassing that breaks up normal stratification only occurs above the sump.
I do not know the extent to which this process occurs, or just how deleterious this process is.
--vtMaps4 X 235watt Samsung, Midnite ePanel, Outback VFX3524 FM60 & mate, 4 Interstate L16, trimetric, Honda eu2000i
- 234 Forum & Website
