Equalizing current for Trojan L16
706jim
706jim Solar Expert Posts: 523 ✭✭✭✭
I'm aware that equalization of an L16 will require about 31 volts. That said, what current would be necessary once the battery starts bubbling?
    Somewhere around 2.5% to 5% of the battery bank's C20 capacity should be plenty of equalization current (for flooded cell lead acid batteries)...
  • 706jim
    Thanks Bill. My 35 amp inverter charger should be adequate for the task then.
    Dave Angelini Solar Expert Posts: 7,030 ✭✭✭✭✭✭
    And you do know that the battery must be fully charged first before EQ is attempted. A battery that will not charge normally should not have EQ unless you know what you are doing!
  • inetdog
    +1
    Applying Eq voltage without current limiting to a battery which is not yet fully charged would be a really bad idea.
    SMA SB 3000, old BP panels.
    Personally, as I understand "equalize"--Yes the battery is "mostly fully charged", and the equalization voltage levels is what "sets" the equalization current to ~2.5 to 5% rate of charge.
    If you hit with "equalize" voltage to a discharged battery bank, you should get a "surprisingly" high charging current (or the battery bank will simply not be at the equalize voltage set point).
  • Johann
    Johann Solar Expert Posts: 245 ✭✭✭
    And for how long should equalizing be done?
    And how frequent in days or month should it be done?
  • Vic
    Hi Johann,
    Speaking of Flooded batteries, in general, each battery manufacturer has specific advice on Equalization. Some say to EQ every specific time interval. Some say to EQ when the spread in SG readings is greater than a certain number of "points", etc.
    Here is a link to the Surrette Battery Manual. On pages 16 and 17, is a summary of What Surrette recommends for their Flooded batteries:
    http://rollsbattery.com/public/docs/user_manual/Rolls_Battery_Manual.pdf
    FWIW, Vic
    Awe Heck, I LOVE this one!
    Trojan doesn't recommend a maintenance equalizing in their instructions. Unless
    Yet appear to disagree with themselves with this instructional video, suggesting monthly equalizing;
    https://youtu.be/jCl5klSF4tE
  • Blackcherry04
    The biggest problem with this is that once you notice 1.235 SG level on a L16 it's doubtful that the sulfate would ever be able to be removed.
    Photowhit wrote: »
    They are in the business of selling batteries! Yes I also saw that! Good stuff for late night reading and insomnia.
    In a rare situation where the user is not looking at cell temperature, has a bad terminal or small cable, they could get a failure mode that escalates. It would be hard to do with a 35 amp charger but further updates from the OP shows that he could use the additional advice!
  • Johann
    Vic wrote: »
    Hi Johann,
    FWIW, Vic
    Thank you for the link. I try to get a feeling and info about batteries and do not know anything about them.
