combiner
Hi ws,
In this installation manual, the right photo on page 1 shows what I believe is this exact GFI assembly mounted in a remote Combiner:
http://www.solar-electric.com/lib/wind-sun/GFP-install.pdf
Yes, it is a good idea to install a high-quality Surge Protector, like the MidNite MNSPD line of protectors.
My opinions, FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
actually what I want is a box that holds 5 mnepv breakers and a mndc gf63 and a lightning bulb. I dont think the 6 will hold all that....do you know a cheap one that will??
Midnite Solar MNPV6 combiner - can you put 3 breakers AND a mndc-gfp63 inside this unit??? what about a lightning surge bulb too???
OK, ws,
So, if your PV string configuration can use 150 V MNEPV breakers, how about the MNPV8 Combiner (?):
http://www.solar-electric.com/installation-parts-and-equipment/midnite/pvarco/pspv.html
