Eco-Worthy 20a MPPT charge controller review.
2»
  • kjetil
    kjetil Solar Expert Posts: 31
    I bought this Eco-Worthy controller now. :D It can handle 550W and 45Voc according to the manual. That means I can use 2 X 250W 24V panels in parallel but not in series?
    The mppt demo is showing some strange numbers. I connected a 22V powersupply with an almost fully charged battery with the controller in float mode. With multimeter I measure 0.3A between the psu and the controller, and 0.3A between the controller and the battery. But MPPT DEMO is showing 7.55A PWM 7.50A Eff01%
    Are the numbers wrong? Or are these numbers just from bulk mode?
  • jimindenver
    jimindenver Solar Expert Posts: 59 ✭✭
    The demo mode is a gimmick. Something to reassure after purchase that getting MPPT was a good thing. A waste of space and cost that should have been used better to improve the controller features. I have found it fairly accurate at showing what the Isc of the panel is only because I didn't believe it. Demo mode showed my 230w panel a amp over it's Isc so I put a meter on it to see.
  • kjetil
    Okey, so it's normal that the MPPT DEMO isn't near what the actually current is?
    I was just unsure because the numbers was so high (over 7A) when I measured 0.3A. I wanna make sure it's nothing wrong with the controller and have to return it?
    Remember that (ignoring losses), that Power = Voltage * Current, or for a MPPT controller:
    Vpanel*Ipanel = Vbatt * Ibatt
    Or:
    Ipanel = Vbatt * 1/Vpanel * Ibatt
    The equation should match to within 5% or so (typically MPPT controller is around 95% efficient at middle of the day solar power).
  • kjetil
    I just wonder why the MPPT DEMO has so different current numbers than the actually current reading?
    DEMO = MARKETING function?
    If you do not use "DEMO"--Does the controller work correctly? If so, then all is good.
  • kjetil
    Yes, It seems to work correctly if I don't use MPPT DEMO.
    1.77A in
    2.82A out
    I was just confused by the high MPPT DEMO numbers.
  • scrubjaysnest
    scrubjaysnest Solar Expert Posts: 175 ✭✭✭
    I would say Demo mode is just that, like a fish finder in demo mode isn't real world just an example.
  • kjetil
    What is Isc?
    Is demo mode pointless and useless? I thought I could read the current from the solar panel in demo mode? But my numbers are way off...
    Isc is short circuit current of the panel under noontime sun.
    Isc is used as the current value to design wire gauge / sizing.
