Is BALQUON ( LiFePo4 maker ) still alive?
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
Since the Tesla battery announcement came out I have not been able to connect to Balqons site http://www.balqon.com/ . It's been over 3 weeks now.... Anyone else having this problem?
I had no problem , it's a new home page with lot's of stuff on it, slow to load.westbranch wrote: »Since the Tesla battery announcement came out I have not been able to connect to Balqons site http://www.balqon.com/ . It's been over 3 weeks now.... Anyone else having this problem?
OK I must have a time out issue... it spins and spins........ and then I get a "problem loading page" msg...
tks BC04
I don't know what is happening, cleared cookies, dumped cache , added that web site to the exception allowed list tried Chrome, still nothing ??
The link works for me and the site loaded up pretty fast. Have you tried a speed test on your internet connection?Off-Grid in Terlingua, TX
5,000 watt array - 14 CS 370 watt modules - 7S2P. HZLA horizontal tracker. Schneider: XW6048NA+, Mini PDP, MPPT 80-600, SCP. 390ah LiFeP04 battery bank - 3 Discover AES 42-48-6650 48 volt 130ah LiFePO4 batteries -
Wheelman55 wrote: »Have you tried a speed test on your internet connection?
Just did and as usual 15 Mbps, 14.76 actually... everything else ( so far ) works but that site
boy I ran into a boars nest, something I did affected both Firefox and IE , lucky I had Chrome installed too, had to beat my way past the blocks Chrome puts in your way to stop you adding FF back on... IE does it too but unable to find the way past the blocks... BEWARE!
Some ISP's have very lame DNS look-up. You may want to try a 3rd party DNS service.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
