Solar Panel Question - Basic
rktortr
rktortr Registered Users Posts: 2
Hi All,
Searched, but clearly not using the right terms. I have a very basic question about solar panel output.
Do solar panels typically output:
1. constant voltage, variable current based on amount of available solar energy, or
2. constant current, variable voltage based on amount of available solar energy, or
3. both current and voltage vary based on amount of available solar energy.
Surprisingly difficult to track down. Thanks for indulging me.
    Pretty much #1, volt will fluctuate a bit due to temperature higher temps slightly lower voltage lower temps slightly higher temps.
    You can look for a temperature coefficient in the spec sheet for a solar panel to give you some idea.
    And, as current draw is reduced, the voltage will rise to Voc. Voltage open circuit (when no current is flowing).
  • rktortr
    Perfect. Thanks so much for the responses.
    Interesting on the Voc. I had always assumed that it was literally for an "open circuit", i.e. no closed wiring (like when a panel is not connected to anything), not just no current/draw. Thanks for the clarification.
    Open circuit and no current draw is pretty much the same thing on different words.
    Note that charge controllers while not drawing current (battery full), are still connected to the solar panel. So if Voc is too high (panels in series, very cold weather, etc.,) it is possible to damage the charge controller input circuitry.
    Matching panels to charge controller to battery bank is actually not a trivial exercise to design correctly.
