FYI, Gas Stove Ignition.
solorone
solorone Solar Expert Posts: 257 ✭✭✭
If this is plowed ground then please remove.
Awhile back ( 1 or 2 years) there was a thread I can not find, about power consumption of gas stoves. At the time I wrote that I could not see any appreciable power usage with my stove. Now after rebuilding my aged system, I had a look the other day at all phases of using the oven. There must be an electronic igniter on this stove, there is a listed spark Module on the schematic, for unlike the gas dryer, there is absolutely none, Nada, no power fluctuations on the xantrex, or fluke.
The stove is a basic generic Whirlpool. No where on the 10 pages is there a model number ???? Must be on the back.
  • Graham Parkinson
    Graham Parkinson Registered Users Posts: 179 ✭✭✭
    Solorone
    That would be good info to get - serial number of a readily available Whirlpool stove with no glow bar power consumption!
    Hope you find the model number somewhere. I was thinking of getting one of the Unique brand stoves with spark ignitors but heard of some issues with them. Pity, as they seem like a good design. The other spark ignition stove I know about are the Premier brand stoves.
    Graham
    Offgrid in cloudy PNW
    Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries, Slimline enclosure, Lynk II, AGS, H650,  H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
    We ended up with a 2011 Viking range with spark ignition for the oven and broiler (and the burners) doesn't even register on the inverter till the oven chassis cooling fan starts up :(
  • solorone
    Solorone
    Graham
    Remind me next week, and I might tackel the job when I get back.. After 10 years, I guess it could use a dusting behind it.
  • john p
    john p Solar Expert Posts: 814 ✭✭✭
    My stove like every other gas stove I have seen uses a piezo ignition.. it provides a high voltage spark to light the gas.. it gives a kick if you touch the pin while turning the gas supply knob.. As I found out when i took it apart to clean it..; they last for years and have never had one give trouble even on cheap Chinease single and 2 burner portable gas stoves
  • Alaska Man
    Alaska Man Solar Expert Posts: 252 ✭✭
    I have an older stove with pilot lights, no power needed. Not even a battery.
  • beachman
    beachman Registered Users Posts: 5
    Peerless makes good new stoves with pietzo ignition. No glowbars and a multi-spark for the burners and the oven. Ben's Discount in Nevada has many gas appliances including a wide selection of Peerless stoves. I can light these with a small battary pack.
  • solorone
    Alaska Man wrote: »
    A wild guessamet, would put a gas stoves pilots at about 20 gallons of LP a year, maybe a lot more. For me that is $40, and I try to avoid that, having a gas stove for canning on the front porch, we keep the gas turned off when not in use.
  • john p
    Iwas in a big hardware store this morning and looked at about 2 gas stoves ALL used piezo ignition.. Asked the salesman and he said he knew of no other gas lighting method ? 60yrs ago when child remember all gas stoves needed lighting with either matches or flint gas lighter. gas hot water systems used a pilot light.
  • offgrid me
    offgrid me Solar Expert Posts: 119 ✭✭
    john p wrote: »
    In the US most stoves use piezo for the gas burners and a glow bar for the oven. The glow bars use around 400w and are powered whenever the oven is trying to heat or maintain temp. They actually use quite a bit of power when cooking for a long time like 5 hrs for a turkey. I think mine used 1.2kwh last Thanksgiving.
  • Alaska Man
    solorone wrote: »
    I used to just turn the gas bottle on and off when the stove wasn't is use. Then the wife found me and we got hitched and I got a new roommate, She decried the lighting of a match all the time or the need for a bended knee to light the oven. Seeing as how my pig headed ways drove the last one off, I relented to the extra $40/yr in propane.
    I have learned. "If Momma ain't' happy, nobody is happy" to be a true statement of fact.
