Solar charging series or parallel for MPPT to 12v battery
gqroot
Registered Users Posts: 22 ✭
Hi folks,
I am building a off-grid system to power up 12 watt device running 24 hrs. The build of materials below. I am wondering if I should get a pair of 12v 100 watt panel in series or in parallel to charge my 12v battery. I get about 2 hours of sun and trying to spec it for 2 days without the sun. Is it better to have the solar panel in series or in parallel when the cable run is 25 feet?
1x MorningStar SunSaver SS-MPPT-15L Charge Controller
1x Concorde PVX-340T Sun Xtender Solar Battery 12V
2x 12v 100w Solar Panel
Thanks in advance!
Thanks in advance!
Ignoring Solar for the moment...
[note: I messed up here--25 feet and 12 watts--See following post for corrections]
That battery seems awfully small for your application (12 volt @ 34 Amp*Hours??):- 12 volts * 34 AH * 1/25 watt load = 16.3 hours until "dead"
- 25 watts * 24 hours per day * 1/12 volt battery bank * 2 days * 1/0.50 maximum discharge = 200 Amp*Hour @ 12 volt battery bank
Thanks Bill for getting back. I have to use a sealed battery because I will be mounting the solar panel and battery box rig on top of a light pole that is approximately 90 feet high. The structural engineer may have some reservations with me putting my rig that is over 100 lbs. So far I calculated 85 lbs. I guess my other option is to put have the battery box on the bottom of the light pole. The light pole won't have 120v power for 3 years.
I would suggest placing all serviceable components at the base of the pole--Unless you have easy/cheap access to a lift.
Of course, that gets security questions (if a problem). Possibly place the electrical box at a lower height (use a ladder).
And "Oops...". I got my numbers mixed up, you are running 12 Watts, not 25 watts--Mixed the numbers up in my earlier post:- 12 volts * 34 AH * 1/12 watt load = 34 hours until "dead"
- 12 watts * 24 hours per day * 1/12 volt battery bank * 2 days * 1/0.50 maximum discharge = 96 Amp*Hour @ 12 volt battery bank
- 12 watts * 24 hours per day * 1/0.77 charge controller+panel derating * 1/0.90 AGM batt eff * 1/2 hours of sun per day = 208 Watt array minimum
- 96 AH battery bank * 14.5 volts charging * 1/0.77 panel+controller derating * 0.10 rate of charge = 181 Watt array recommended minimum size (10% rate of charge)
You started this as a wiring length question--Solar panels mounted on pole? And yes, I probably would use the two solar panels in series to allow a smaller awg wire. Using a generic voltage drop calculator:- 2 * 100 Watt panels * 1/35 volts Vmp-array = ~5.71 amps Imp
- 0.03 maximum recommended voltage drop * 35 volts Vmp-array = 1.05 volt maximum drop
14 AWG wire:
Voltage drop: 0.72
Voltage drop percentage: 2.06%
Voltage at the end: 34.28
10 AWG wire:
Voltage drop: 0.29
Voltage drop percentage: 0.83%
Voltage at the end: 34.71
So, I would suggest around 14-10 AWG wire as being optimum for this installation.
Thanks BIll for your help! To squeeze as much volts from the panel and not lose it too much is to use as you suggested 10 AWG. Thanks again!
