Old posts deleted ? Were did I go ?
Skippy
Solar Expert Posts: 310 ✭✭
Well, still getting used to this new format, one question though, were did I go ?
My thread on the solar powered shed is gone. Checked all 20 pages of history. . . am I missing something, or was I dropped ?
I haven't given up on the project, just waiting for spring ..
Even went into my settings too check on my "all my posts" - and it's gone.
2 - 255W + 4 - 285W PV - Tristar 60 amp MPPT CC / 3 - 110W PV -wired for 36V- 24V Sunsaver MPPT CC / midnite bat. monitor.
420 Gallon rain water system for laundry.*** 6" Rocket Mass Heater with 10' bed for workshop heat.
Current project is drawing up plans for a below grade Hobbit / underground home.
Google "undergroundandlovinit" no spaces.
I tried a few searches via Google and didn't find anything either.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
I replied in the other thread for the starting threads I could find.
Skippy, if you know more of the key words/phrases, you can use Google Search to find the posts. Something like:
site:Solar-Electric.com Skippy solar powered shed
For some reason, the + and - Google tags are not working correctly at the moment (sees it as a "plus sign", not as "must include" in search results).
That is basically the Google query I used, with nothing promising. I think "must include" words need to be included in quotes.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
