A test thread
vBulletin Support
Administrators, Solar Expert Posts: 112 ✭✭✭✭
Aye Aye Captain, read and ignore. (but what fun is that?)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Nothing to see here.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
These aren't the 'Droids you are looking for...
I found it a very interesting thread..Keep up the good work My only other activity today was watching some paint dry..
A little testy for me too, now for another dram... oops sun not over the yardarm yet
Nothing new here.2 - 255W + 4 - 285W PV - Tristar 60 amp MPPT CC / 3 - 110W PV -wired for 36V- 24V Sunsaver MPPT CC / midnite bat. monitor.
420 Gallon rain water system for laundry.*** 6" Rocket Mass Heater with 10' bed for workshop heat.Current project is drawing up plans for a below grade Hobbit / underground home.Google "undergroundandlovinit" no spaces.
