2ng generation Electrodacus lithium BMS
jonr
Solar Expert Posts: 1,386 ✭✭✭✭
This is worth reading even if the case for lithiums may be overstated. I have no financial involvement other than being a reasonably satisfied customer of the first model. It is a PWM controller.
http://electrodacus.com/
Thanks for the information
Interesting that both Bosch and Sony are developing LFP storage systems and giving lifespans of around 20 years for the batteries. I wonder if the Winston batteries will last as long as the batteries being used by Sony or Bosch. If I get ten years out of mine I will be very happy.
SimonOff-Grid with LFP (LiFePO4) battery, battery Installed April 2013
32x90Ah Winston cells 2p16s (48V), MPP Solar PIP5048MS 5kW Inverter/80A MPPT controller/60A charger, 1900W of Solar Panels
modified BMS based on TI bq769x0 cell monitors.
Homemade overall system monitoring and power management https://github.com/simat/BatteryMonitor
Jon, are you doing one of your hard tests on it?
I noted with interest his comment about the efficiency of the LiFePo4 vs FLA on charge and discharge, that's another factor in LiFe's favour...
My testing is being held up by price and shipping issues on lithium batteries. On the other hand, I reviewed the 1st generation design pretty thoroughly.
It would be good to see a photo one here of the new one compared to the previous one he displayed..
- 230 Forum & Website
