Need out door DC Disconnect
verdigo
Solar Expert Posts: 428 ✭✭
Need an out door DC disconnect. Local inspector says my Midnite combiner won't cut it. Found this http://www.amazon.com/Square-Non-Fusible-600V-Disconnect-HU361RB/dp/B000LDEXM2#productDetails on Amazon but it says its only 30 amps. Also will my Classic 150's arc fault protection keep one or two of these from welding itself together?
Dennis
Dennis
Re: Need out door DC Disconnect
look through these...
http://www.midnitesolar.com/products.php?menuItem=products&productCat_ID=26&productCatName=Combiners,%20Disconnecting
There is also a 60 amp version of the Square D swich you saw on amazon. If I remember correctly it is about the same price. solarvic -
Re: Need out door DC DisconnectThere is also a 60 amp version of the Square D swich you saw on amazon. If I remember correctly it is about the same price. solarvic
Found it. HU362RB. Thanks. Another on of those unplanned expenses that really add up. -
You would have been much better off with the Midnite Disconnecting Combiner that Westbranch suggested...
The Time and Materials to install that square D disconnect will really add up. -
Re: Need out door DC DisconnectYou would have been much better off with the Midnite Disconnecting Combiner that Westbranch suggested...
I would rather have the midnite box, but as far as I can tell it is not UL listed and that, according to the electrician I am using is what the inspector wants.
The Midnite box would also be cheaper considering I already have the string breakers that go in it. This. http://www.solar-electric.com/bisoshoff.html is what the electrician described that the inspector wants, and by itself does not constitute a disconnect.
Right I am now trying to get an appointment with the inspector to get the story straight from him without any misunderstandings from the electrician. -
Re: Need out door DC DisconnectI would rather have the midnite box, but as far as I can tell it is not UL listed and that, according to the electrician I am using is what the inspector wants.
They are ETL (us) listed which passes NEC code anywhere in the US, though they might have some legislation that requires 'UL' most of that is invalid from case law and likely legacy legislation.
Link to pdfHome system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Re: Need out door DC DisconnectThey are ETL (us) listed which passes NEC code anywhere in the US, though they might have some legislation that requires 'UL' most of that is invalid from case law and likely legacy legislation.
Link to pdf
I am aware of the ETL listing. I just need to educate the inspector in a way where he thinks it is his idea. -
Ask him this way :
Does the disconnect need to have an outside handle that will disconnect all the solar strings with one motion? -
Hmm some one was just trying to tell me the other day on here that "the inspectors don't really look at, or care about the DC side".Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
I was reading through this document http://solarprofessional.com/articles/design-installation/understanding-the-nec-2014-and-its-impact-on-pv-systems?v=disable_pagination and it states up to six breakers within one box is acceptable. I hope to catch up to him this week.
- 234 Forum & Website
