Over equalization?
I have 3 100 watt panels feeding 4 T105 batteries through a C40 controller at my cabin in northern Maine. I manually equalized them in November, when I returned 3 weeks later I discovered I forgot to turn off equalization. They now do not seem to be charging properly. Could I have fried the batteries?
  • Blackcherry04
    Re: Over equalization?
    Gbmason wrote: »
    It will only Equalize for a hour at a time and has to be re-triggered, so your fine unless it got stuck in some way. If the batteries still have any water in them , then it didn't EQ for three weeks. they would very hot.
  • Gbmason
    Gbmason Registered Users Posts: 4
    The controller was still in equalize mode (flashing red and green) when I returned. The system's voltage will not go much higher than 12.9.
  • Blackcherry04
    Gbmason wrote: »
    Sounds like something is wrong with it. The EQ voltage is one volt above the Bulk / Absorb setting. Did they still have water above the plates ?? Is the automatic jumper in place ??
    I'd take the battery power off it and let it re-start and then test it.
    Are they arranged 4S(in series) or 2SX2P ? ie 24V or 12V configuration?
  • Gbmason
    westbranch wrote: »
    2sx2p 12 volt. I don't know for sure if it's the controller, could be? With the system fully connected I get the battery voltage through to the panel connection point, typically around 12-13 volts. When I disconnect the panels from the system I get 22v at the panel connection point. Thanks all for your inputs.
    1). Check electrolyte level in batteries.
    2). Check SG of every cell.
    3). Bypass charge controller and see if batteries charge (you must watch this carefully).
    4). In future do not use EQ unless needed.
    5). Get enough PV to actually charge the batteries: 300 Watts isn't going to do it for 450 Amp hours @ 12 Volts. You need closer to 800 Watts.
  • Gbmason
    I've checked electrolyte levels all ok
    I tried to check SG, but my tester wasn't reading, the "bobber" stayed on bottom.
    So I should connect the panels directly to the batteries and monitor them?
    Definitely will not EQ but 2 or3 times a year.
    I have 2 more 100 watt panels to install in the spring. Maybe I should purchase 3 more.
    Thanks a lot.
    Sounds like you need to thoroughly clean your hydrometer, or replace it. Vital tool, that.
    Connecting the panels directly will tell you if the charge controller has failed. But you will have to monitor the battery Voltage and disconnect whenever it rises to 15 Volts. Don't just hook it up and walk away. After a day of that you should see a rise in SG and Voltage. If not, the batteries are ruined.
    The C40 may need to be replaced anyway if you actually go for full 45 Amps of current. This is where you start re-evaluating the whole system, beginning with loads and how much actual battery capacity you need. It may even be time to bite the bullet and go up to 24 Volts.
  • 706jim
    706jim Solar Expert Posts: 524 ✭✭✭✭
    Gbmason wrote: »
    The C40 automatically shuts off equalization after 2 hours so you should be fine.
    Either you have a problem with the C40 or it was somehow set to 24 volts and the batteries never got to that voltage.
