Fouling
CALLD
Solar Expert Posts: 230 ✭✭
It's one of this things, you put up your panels, connect everything up and switch it on. After you have calibrated your system and finally got it firing on all cylinders you aim to sit back and watch the magic happen. You have stressed about the batteries and how to keep them running optimally and after some time you have it nailed!
Then, on one of those glorious sunny mid-summer days you stroll over to the charge controller anticipating that smug feeling you get when you see your system running at full-steam giving you that warm fuzzy feeling that can only come from knowing you are plugged directly into the most awesome nuclear reactor within several light-years!
I did that today - fully expecting to see around 28 amps are thereabouts streaming into my batteries. It was mid-day after all and not a cloud in sight. Instead the charge controller reading was 11.8 amps, then 16.4, then 13.2, 14.3, 21.5, 10.9, 15.0 etc...
Those pesky crows having a party on my panels again!!!!!
The life of an off-gridder is so interesting........
Re: Fouling
Don't feel so bad, I have only seen the sun three times this month and then not for the whole day. The continual moister and snow has kept my panels pretty clean.
Cheers
gww -
Re: Fouling
I had that problem with pigeons. They learned about lead poisoning really quick. I still see some but not on my roof! LOL -
Re: Foulingsolar_dave wrote: »I had that problem with pigeons. They learned about lead poisoning really quick. I still see some but not on my roof! LOL
Lead acid batteries I take it?Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year. -
Re: FoulingLead acid batteries I take it?
While I wouldn't presume to speak for solar_dave, I rather suspect that the pigeons in question were tragic victims of Lead-Moderated Kinetic Energy Poisoning (IYKWIMAITYD)....
ETA: My original thought, upon seeing both the title of this thread and the nature of the event that inspired it, was that the thread title could easily have been spelled "Fowling," with little loss of accuracy (though they are also birds, crows are seldom viewed as poultry...). -
Re: Fouling
Try one or more of these:
http://www.gemplers.com/product/G73500/Rotating-Head-Owl#TAB-REVIEWS
http://www.gemplers.com/product/221414/Solar-powered-Owl-Rotating-Head?pfx=OAWP
Crows are smart, so you have to move it around to avoid acclamation.23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring since 2011 -
Re: Fouling
Crows are indeed that smart. Someone gave me a few alpacas. Suddenly neighborhood coyote activity picked up considerably. Then it seemed that a crow was sitting on the roof and calling in more coyotes. Figuring he (the crow) would enjoy plenty of left over pickin's. In four years, there was never a crow making calls on the roof at night,Try one or more of these:
Crows are smart, so you have to move it around to avoid acclamation.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Re: Fouling
It really is well and truly bird-bomb season here now, two of my 300w panels looked like they'd been blasted with a poop shotgun this morning! Interesting thing though is after cleaning them off the production only increased from 22.5 to 23.4 amps at 09:30 despite the awful state they were in...
- 230 Forum & Website
