Need a decent 300w 24v psw inverter?
K4KMG
K4KMG Solar Expert Posts: 50 ✭✭
Need one to run 24/7. Load would be minimal, maybe 50-75w max. I know I can get a Chinese, but concerned as I wont be around Monday thru Thursdays to keep an eye on it. Need it for a small load at my camp, (see here: http://k4kmg.com), during the week when I'm away. Prefer not to spend a bundle!
Any thoughts?
Tom
    Re: Need a decent 300w 24v psw inverter?
    Would a small, purpose built 12 v system be better (cheaper?) for those security cams rather than a 48v inverter?
    Good quality 300 Watt 24 Volt Samlex http://www.solar-electric.com/inverters-controllers-accessories/inverters/sasiwain1/samlex-pst-series-pure-sine-wave-inverters/sa300wa24vos.html
    If you're sure that's what you want.
  • K4KMG
    Thanks but I've already called NAS about this one. From the description:
    'If you plan to use devices for extended periods, you may want to consider the more efficient SA series of inverters from Samlex. '
    Price is right but they said heat might be an issue if it's on 24/7. Unfortunately the SA series is quite a bit more expensive.
    At less than 100 Watts load? I doubt it.
    And if you buy a Chinese wonder what guarantee will you get that it won't just fry instantly? None.
  • H2SO4_guy
    H2SO4_guy Solar Expert Posts: 213 ✭✭✭
    Check out Exeltech pure sinewave inverters. Just make sure that you get the correct voltage. They make from 12 - 108 volts input. Very high quality and NAWS sells them, although I have purchased several on Ebay for a very good price. They also make a 125 watt version that would probably work for you. I have purchased them in the past for $75 or so.
    Good luck and let us know how it works out.
    12K asst panels charging through Midnite Classic 150's, powering Exeltechs and Outback VFX-3648 inverter at 12 and 48 volts.  2080 AH @ 48 VDC of Panasonic Stationary batteries (2 strings of 1040 AH each) purchased for slightly over scrap, installed August 2013.  Outback PSX-240X for 220 volt duties.  No genny usage since 2014.
    Inverters with remote on/off switches are very nice (I don't remember any of the Exeltech having remote on/off). It is a pain to use a relay. Although, if you use a large DC rated circuit breaker (instead of a fuse)--That is a pretty easy way to turn the inverters on/off.
    I think only 600watt and above.
  • K4KMG
    Thanks but no way to access remotely anyway.
