inverter not working in extreme cold
Joe94
Joe94 Solar Expert Posts: 42
I've been out working on my place the last couple weekends and the overnight temps have been in the single digits. When I wake up in the morning my inverter is not working, by about 10:00am everything is working fine again. I have 500 watts of panel charging a 440ah bank with a suresine inverter. I can't imagine I'm over taxing the system I'm only running few lights in the evening and charging my iPad. Probably a few hundred watts tops. Every thing that is wired for 12v runs fine but no inverter. It's only happened to me twice on very cold nights. I probably just need to get my volt meter out and test some things but I thought I start here for some pointers.
  • waynefromnscanada
    Re: inverter not working in extreme cold
    Joe94 wrote: »
    Having had two Suresine 300 watt inverters running for about 5 years, one 24/7, the other on power-save, waking up when it's loads turned on, and both located in an unheated outbuilding where the temps regularly dropped to minus 20C (0F) and sometimes minus 25C, I've never had a problem with the inverters shutting down other than when I grossly overloaded the tough little buggers. I've since replaced them with higher wattage inverters due to ever increasing loads.
    My first thoughts about your situation is - - - battery voltage, especially with the days getting ever shorter and stormy this time of year as Winter approaches, resulting in less and less charge going into the batteries each day. Friend of mine recently ran into the same problem and killed his year old batteries. Deficit charging situation gradually brought his batteries to a lower and lower state of charge until finally the inverter started shutting down on low voltage.
    Don't forget, the inverter if running continuously is also a load on your batteries. A load you don't see and therefore may not be aware of. If you don't need it running at night, shut it off. But first things first, and that's to try to salvage your batteries, hope they haven't sulfated and that they will take a full charge.
    cold and shorter days. Cold reduces your battery bank capacity Old batteries have reduced capacity
    "a few hundred watts" is a pretty large load for a suresine (300w cont) AND your batteries. does your charge controller have any voltage indicators on it ? Temperature compensation for the charger (cold weather needs higher voltage) ?
  • Joe94
    I need to remember my volt meter next time I'm out there. I'm not there full time just on weekends right now and this last weekend was the first time in two weeks. when I'm not there I shut down the inverter so it sits all week with no load just charging. My charger is a midnight classic with a temp sensor on the batteries. When I say I'm using a few hundred watts, I mean total for the whole night. the inverter is still working when I go to bed and everything is turned off. I wake up and no inverter, all my 12v equipment works fine lights water pump exe.
  • Blackcherry04
    Well, it's either the battery voltage or the Inverter is going into standby and not enough load to pull it out or it's defective, I have one that will go into standby and I have to reboot it if I ever let it go into standby, it won't come out on it's own, would be my $.02.
  • icarus
    My guess is that you re using more power than you think, and/or your batteries are/have been chronically undercharged, such that the inverter goes to disconnect. I would do a real evaluation of your loads and charging, and look at the basic health of your batteries. The fact that you state "Tht I can't imagine I'm over taxing the system" suggests that you have no real idea how you are loading and charging these batteries.
    Good luck and keep in touch,
  • waynefromnscanada
    icarus wrote: »
    The fact that you state "I can't imagine I'm over taxing the system"
    And that's almost exactly what my friend said when told him I strongly suspected his batteries were dead from his using more power than his 15 watt panel could replace.
  • Joe94
    icares, thanks for the reply, I have a very good sense of what my loads are and why feel comfortable saying I'm only using about 300 total through the night. With every light on in the whole house I'm only drawing 95watt hours and I don't leave every light at once. I probably ran a few lights for three hours on Saturday night. The only other thing I'm powering is a charger for my iPhone and ipad. Saturday before the sunset I checked my Classic and it was float charging. I can't be running a constant deficit because When I'm not there all week I turn the breakers to all the loads off. Also worth noting is that my water pump runs on about 14amps at 12v and I turned it on Sunday after I noticed the inverter wasn't working. It filled my pressure tank with no hesitation. If I had week batteries or a low voltage situation I would think the pump would have struggled. My thought was that maybe my batteries are getting cold over night and the classics temp sensor is causing it to increase the charge voltage to compensate and that is causing a high voltage disconnect situation. It only shuts down first thing in the morning and that is when it is coldest out and it is starting to charge again. I could be wrong but I thought i would pick everyone's collective brain.
  • waynefromnscanada
    A good voltmeter will tell the final, true story. Until then, we're all just giving it our best guess.
  • Joe94
    I agree that I need to just go back out with a voltmeter and check but, I thought I would see what everybody thought some likely causes could be so I had some good direction when I start checking. If the batteries are low/under charged or there was a charge deficit the Classic wouldn't be float charging them would it?
  • waynefromnscanada
    Joe94 wrote: »
    True. UNLESS the Classic is set for a different type of battery and goes into Float far sooner than it should for these batteries.
    The other possibility is the capacity of the battery bank has been badly reduced, perhaps due to sulfation for example, or are otherwise worn out so they reach their "full charge state" very quickly, then discharge just as fast. The meter and time will tell.
  • icarus
    Chronically undercharged/overdrawn batteries will get to "full charge" even though they have little capacity.
    I suggest you do a good charge cycle, and then a load test.
    I'm not sure you understand the difference between watts and watt/hours since you mention only running "95 WH". Are you saying that you routinely run 300 watts of load, or 300 WH total per day? 300 WH out of a 12 v battery bank is ~ 25 ah. The point is, try to get a real handle on your loads ( and charge regimen) and then figure out if you are really living within your means, so to speak. Also charge and load test the bank.
    As for the cold, 0F is not that cold for batteries. If the cell temps are really that cold, you have a capacity significantly lower than at 70f. But will still be above ~60%. It is also unlikely the batteries are as cold as the ambient, unless they are subjected to wind. 0f overnight, might warm to 15 above during the day, and if they are inside the building will give them some heat, and they will develop some heat from PV charging. So your battery temps are likely to be several degrees F warmer that 0.
  • Wxboy
    Wxboy Solar Expert Posts: 70 ✭✭✭✭
    My vote is for high voltage from temperature compensated charging shutting down the inverter. It doesn‘t sound like a battery problem if it ran the pump fine.
    The classic has a meter on it for the battery voltage. Whats it reading evening, and morning ?
    A dumb pump sounds the same on 12V as it does on 11V, it's NOT a good indicator of charge.
  • waynefromnscanada
    Wxboy wrote: »
    Ah - - - - it's not happening during daylight, it happens during the night.
    And that takes us back to failing batteries...:cry:
  • Joe94
    Both times I've noticed that the inverter is not on it has been 9:30 or so in the morning when the sun is out. The inverter usually comes back on by 11:00 or so. I have no idea when it stops working.
  • waynefromnscanada
    Joe94 wrote: »
    Both times I've noticed that the inverter is not on it has been 9:30 or so in the morning when the sun is out. .
    What time does the sun strike your panels in the morning? How long has the sun been on the panels before you notice the problem? This time of year there is normally very little output from panels at or before 9 AM. At least in my part of the world.
  • Joe94
    My place is in the desert so there are no obstructions. Sunrise this time of the year is 7:30. I don't know what time the inverter is shutting down. I don't use power in the morning usually. my house faces into the sun so I don't need lights and I cook with gas. This last weekend it was about 9:30 that I noticed the inverter was out. Last time it happened was two weeks earlier same situation it was mid morning single digit temps overnight. I tried to plug in my phone and noticed there was no ac power from the inverter. About an hour later everything worked fine.
  • waynefromnscanada
    Will be very interesting to see what the volt meter shows. WXboy could possibly be right. The inverter shuts down when the DC input reaches a high of 15.5, or a low of 10 volts, although I seem to remember the low voltage cutoff being user selectable between 10 volts and perhaps 11.5 volts. I've had overvoltage shut down happen a few times, but only during extreme cold. It would however be unusual for such voltages to be reached so early in the morning unless the batteries were already almost fully charged, or have lost their capacity so APPEAR to the controller to be almost fully charged. The volt meter and WHEN the shutdown actually takes place, will tell all.
  • Joe94
    Update, I spent the weekend out at the house. The inverter did not shut down at all this weekend. It was about 20 degrees warmer this weekend then last. Last night I ran more loads on the system then normal and this morning at about 8:45 I put a volt meter on the breaker panel and was showing 14 volts. I ran things all day long today, and checked the battery voltage sometime after the sun went down. The Voltage was 12.95v. I usually don't draw down the batteries more then few hundred watts per night so its very likely they are mostly charged going into morning. Anyway, I just wanted to report back.
  • waynefromnscanada
    Joe94 wrote: »
    Well it's beginning to look like Wxboy may well be right when he said:
    Wxboy wrote: »
    But to verify, you'll have to see what the volt meter is saying on those cold mornings when the inverter shuts down. If it's reading 15.5 or higher - - BINGO!
    But still, 15.5 is a long way from the 14 you found in the morning. And the next time it shuts down, disconnect the panels from the controller, allowing battery voltage to drop. Inverter should come back on when the voltage drops back to roughly 14, IF the shutdown was caused by over voltage.
  • mryimmers
    mryimmers Solar Expert Posts: 117 ✭✭✭
    My inverter shuts down regularly in the cold weather, if the battery bank is at -13C or colder and battery voltage hits 15.5.
    It shuts down when the CC goes into absorb, I have absorb voltage set at 14.4, temp comp is at 5mv per cell.
    I usually dial the absorb back a couple points so it does not kick out, and bump it up when I am done. I just restart inverter by resetting breaker, not sure if I waited it may come back on by itself when the voltage comes down after absorb is done.
    This is not much of a problem for me as my system is just occasionally and very lightly used.
    Maybe your absorb voltage needs to come down a bit??
    510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
    mryimmers wrote: »
    No.
    You do not turned down the Absorb Voltage because the inverter doesn't like it.
    The batteries need the Voltage to charge with; the problem is with the inverter. If the batteries do not get sufficient Absorb Voltage they will not charge properly and their lifespan will be compromised.
    Either change the inverter, or do the diode trick if you can find some heavy enough to take the expected current. Knocking 1 Volt off what the inverter sees is usually enough to solve this problem as well as effectively raising the LVD (which on these cheap, small inverters is almost always 10.5 Volts which is too low for preserving the battery).
    More expensive inverter-chargers do not suffer from this problem so the diodes are not needed. If they were it wouldn't work as they would effectively block the charge current going back to the battery from the AC source.
  • mryimmers
    What I mean is, is your absorb set higher or at your battery manufacturer's recommendation? And what about your temp compensation? Assuming you are talking fahrenheit degrees, down to "single digits" is right around were my system does the same thing.
  • mryimmers
    This problem of my inverter shutting down due to high voltage in cold weather has really become a PITA. It has been very cold here recently and my battery bank has been sitting around -20C, and due to temp compensation my Suresine 300 is always shutting down (when the sun is shining), as voltage is limited to 15.5 volts. I have been considering how to improve this situation. If this system was used on a daily basis it would really be maddening, but it is only occasionally and lightly used.
    My batteries are in an insulated box, in the tool shed, with the rest of the system. The box is somewhat over sized, so I could add some more insulation, that may help. I could move system into the cabin, but I don't really want to, as this would be a ton of work.
    The Suresine 300 is a great little inverter but it has it's limitations. (15.5v max in this case). I have looked at some at the bigger "real" inverter/chargers, but for my purpose can't really justify the cost, as my power requirements are small. Looking at the other smaller inverters on our hosts site, ie; Exeltech, Samlex, they both list max voltage as 16.5v, which would address my problem I think. The Exceltech is rated to operate in temps as low as -25C, the Samlex is 0C. (The Suresine is -40C). Xantrex models I looked at were only 15 or 15.5 volts.
    If I go the new inverter route I would probably switch to 24volt while I'm at it, as I would only have to rewire the battery bank.
    Just sharing some thoughts as this potential problem did not occur to me when planning things out.
    Yea, inverters with maximum input voltage of 15.5 volts and the same company makes solar charge controllers that will charge over 16 volts in cold regions with temperature compensation.
    If you live in cold climates, you have to just make one more item on the check list--Maximum battery voltage. Samlex, for example, makes two different series of AC inverters--The PST works to 16.5 volts, the SA works to 15 volts.
    http://www.solar-electric.com/inverters-controllers-accessories/inverters/sasiwain1.html
