Small system
Re: Small system
Jim said:As you have determined, the controller is not delivering all available PV power when it’s operating in PWM mode (absorb or float). This is a good time to power an "opportunity load" from the “extra” power. For example, once my controller has been in absorb mode for ~1/2 hour, there’s enough "extra" power available from my PV array to power a 200 W attic fan without affecting the controller's ability to deliver enough charge current to maintain target battery voltage.
Is there a way to automatically turn on such a load when that extra power is available?
John
Re: Small system
As far as I know, not as I described above. The OutBack MX60 has a user-programmable AUX output (12 V x 200 mA) that can activate a relay to control a large load. Check the user manual for more details. The Apollo T80 controller has two outputs for "control of external devices".
HTH,
Jim / crewzer -
Re: Small system
Update:
I said:Update (340-watts of PV - 420ah battery bank - 800 watt/hour per day load):
The cloudy/rainy weather is still with us here in Southern Illinois, and I finally had to remove the load due to low battery voltage. The freezer (load) ran for 24 days up to that point.
I noted that the charge controller stops applying charge current when the batteries are fully charged, and Jim said:As you have determined, the controller is not delivering all available PV power when it’s operating in PWM mode (absorb or float). This is a good time to power an "opportunity load" from the “extra” power. For example, once my controller has been in absorb mode for ~1/2 hour, there’s enough "extra" power available from my PV array to power a 200 W attic fan without affecting the controller's ability to deliver enough charge current to maintain target battery voltage.
Jim, that sounds like a good project for someone with an electronics background. Can you briefly outline the specifications of a circuit or intelligent controller that might perform that function? Thanks!
John
