Blue Light-Emitting Diode Inventors Awarded Nobel Prize
DanS26
Solar Expert Posts: 271 ✭✭✭
Most solar enthusiasts, especially you off grid guys, should be interested in this:
http://www.nobelprize.org/nobel_prizes/physics/laureates/2014/press.html
23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring
Re: Blue Light-Emitting Diode Inventors Awarded Nobel Prize
Only one mistake I see in the article...due to low power requirements it can be powered by cheap local solar power.
Solar ain't cheap!
it would be if all you power is 1 led of modest power level as the proper number of cells could be seriesed that won't need huge currents like that we see in our huge pvs. 4.5v-6v may be all that's needed and depending on the power of the led you could select the right current rating, which should be fairly low as in under 500ma. given a choice i'd use a white led for visibility rather than blue. -
Re: Blue Light-Emitting Diode Inventors Awarded Nobel Prizegiven a choice i'd use a white led for visibility rather than blue.
There are no white LED's (regardless what you see in catalogs) There are Blue or UV LED's with phosphor layers (like a florescent bulb) the phosphors are lit by the diode, and then glow in the desired quality of "white" . Efficiency is lost in this phosphor conversion, so blue gives more lumens than white.
Fluorescent lights are "mercury vapor arc tubes" and produce UV light. Their white phosphor converts the UV to "white". Same thing white LEDs do, convert blue/uv to white with a phosphor package.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
maybe so mike, but our eyes don't respond to the blue wavelengths of light like those in other wavelengths even if the blue has more output.
