Advice on a good wind controller
vomus
Solar Expert Posts: 32 ✭✭
Hi!
I just installed wind maglev turbine for my 48V system and it seems to work well enough. However, it came with a rather bad controller that I would like to replace with something more sophisticated (a Xantrex alike device). Can anyone give any advice on what might be a good replacement?
1) I would like the controller to turn on for as low wind as possible. The one I have seems to wait for quite a while before starting to spit amps into my batteries. It would be nice to collect as many amps as possible. May be there is a controller that can be adjusted.
2) It would be very good to be able to adjust a floating voltage so I could accommodate different types of batteries. The controller I have now has 58V hardwired into its brains but my batteries would prefer 54.4V when they are in a buffer mode. In general, adjusting bulk/absorption/float voltages would be a real plus.
3) It would be really cool if the controller had some remote management option like RS232 or IP and I would be more than happy if it was exposing its parameters through Modbus so I could integrate it into my "smart home" system. :-)
Thanks a lot in advance,
Re: Advice on a good wind controller
I'm not a wind guy... but sounds like a Midnite classic. The Xantrex C40 might work as well, I think some of the voltage levels are adjustable, and it's a PWM controller.
The not delivering and current might have to do with it not spinning up, voltage increases as it spins up and it has to turn at a certain rate before it achieve minimum voltage.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
There are (at least) two different ways of connecting your controller to your battery bank.
The typical method is to have the Wind Turbine:
Wind Turbine => DC rectifier => Battery Bank => Dump Controller => load bank (resistance heaters typically)
In this case, the turbine is always connected to the battery bank and dumping all available energy (Alternator output>Vbatt) to the battery bank. Then a "dump/shunt/diversion/bypass" type charge controller monitors the battery bank voltage--When battery is "full", the controller turns on and dumps current to the resistor bank (waste heat).
Another type is to use a MPPT type charge controller (some with integrated resistor load bank). The MPPT charge controller lets the turbine operate at optimum RPM/Voltage/Current and take the high voltage/low current from the turbine and efficiently down convert it to low voltage/high current needed to charge the battery bank.
Wind Turbine => Rectifier/Load Bank controller => MPPT charge controller => Battery Bank
In theory, it has been reported that some test systems produced 2-3x the energy with an MPPT controller vs the standard PWM Dump controller in example one.
A couple of controllers you can read the instructions on:
Schneider Electric C40 40 Amp Solar Charge Controller (simple PWM diversion controller)
http://www.solar-electric.com/inverters-controllers-accessories/chco/misoclchco.html (Midnite MPPT classic + clipper controllers)
I don't know much about the details of the Midnite system... If your turbine gets good wind and generates significant power normally, then a MPPT type charge controller can help you harvest more.
If you do not get good wind, or get significant power from the wind turbine due to design issues/trees/buildings blocking prevailing wind, then a MPPT charge controller will probably not help you. The turbine has to be generating good voltage/current and you want better. If the turbine barely produces enough voltage to charge the battery bank--The MPPT controller will not help at all as the turbine does not produce a minimum amount of power in the first place.
Re: Advice on a good wind controllerThere are (at least) two different ways of connecting your controller to your battery bank.
In this case what would I do if a voltage from my turbine becomes higher than what a particular battery is optimized for? How do I regulate rectifier's output? In other words this element has to be not just a simple bunch of diods. I have never worked with a three-phase rectifiers which have to be used here and which are somewhat more complex.
The scheme with an MPPT sounds a bit more attractive (mostly because I have a spare Xantrex MPPT60-150 :-)). What will a Load Bank controller do in this case and what can be used for such a purpose? When you say a "Load bank" you mean "Dump load"?
My turbine reaches 46V at rather large winds, about 9 m/s. -
Re: Advice on a good wind controllerIn this case what would I do if a voltage from my turbine becomes higher than what a particular battery is optimized for? How do I regulate rectifier's output? In other words this element has to be not just a simple bunch of diodes. I have never worked with a three-phase rectifiers which have to be used here and which are somewhat more complex.
Actually, the whole turbine/alternator/rectifier is actually quite straight forward... Very similar to the components on an automotive Alternator (without the regulator circuit).
http://www.thebackshed.com/windmill/articles/Rectifiers.aspThe scheme with an MPPT sounds a bit more attractive (mostly because I have a spare Xantrex MPPT60-150 :-)). What will a Load Bank controller do in this case and what can be used for such a purpose? When you say a "Load bank" you mean "Dump load"?
Wind turbines tend to operate with rapidly changing RPM and wind conditions... I do not know if a Xantrex MPPT controller would track a wind turbine well or not (I would tend to think not)... Perhaps somebody here can help answer that question.
Yes, load bank or dump bank--Same thing.My turbine reaches 46V at rather large winds, about 9 m/s.
You have to know more about the turbine than 46 volts... A 48 volt flooded cell battery bank needs about 59 volts or more to fully/quickly charge.
A turbine may output 46 VDC from the rectifier--Which is too low to recharge a 48 volt battery bank... Or it may be getting 46 VAC which will work out to around 60-65 VDC (after the full wave rectifier), which is enough voltage to recharge a 48 VDC battery bank.
Also, the operating voltage is heavely dependent on the state of charge of the battery bank... When the battery ban is well discharged (below 50% state of charge), it may be ~48 VDC when "resting" (several hours of no charging/discharging current). You need to raise the battery bank voltage to a minimum of ~56 VDC to get some decent charging current into the battery bank. A 1,000 Watt @ 48 volt turbine should be able to output ~20 amps in rated wind speed--But man times is much less because of low average wind speeds at the turbine.
Do you have a link to the turbine website/manual/specifications? This sounds like it may be a vertical axis wind turbine. They tend to be mounted too low (less than 10 meter tower) and don't really work well in less than very windy conditions.
Re: Advice on a good wind controllerWind turbines tend to operate with rapidly changing RPM and wind conditions... I do not know if a Xantrex MPPT controller would track a wind turbine well or not (I would tend to think not)... Perhaps somebody here can help answer that question.You have to know more about the turbine than 46 volts... A 48 volt flooded cell battery bank needs about 59 volts or more to fully/quickly charge.
Speaking of the turbine... Yes, it is a vertical 1 kW Maglev. The picture (of a 300W) is here, for example http://www.diytrade.com/china/pd/12283894/300_3KW_Maglev_Wind_Turbine_Wind_Generator.html. It is mounted on a 10 meter tower.
- 626 Discussion Forums/Café
