BTS on Trojan L-16-RE-B
jcheil
Does anyone know where I could put the BTS on these batteries? The sides of the case are not flat, they are a raised checker-type pattern. I'm not thinking it would stick well, nor provide accurate readings because there will be an air gap between most of the sensor and the battery case.
  • DMJ72
    DMJ72 Solar Expert Posts: 131 ✭✭
    Re: BTS on Trojan L-16-RE-B
    jcheil wrote: »
    What charge controller do you have? If this is the type that has the ability to go on the battery terminal bolt .. I would use that instead. Be careful of not making the rookie mistake of putting the BTS in-between the Battery terminal and the Battery wire-lug.
  • jcheil
    DMJ72 wrote: »
    All my equipment is in my SIG, and it is the Outback BTS/RTS. Flat, about 1" by 3" rectangle, 1/8" thick with adhesive tape on the back. No way to get it on a post that I am aware of.
  • DMJ72
    Oh, yes. Well I had that problem with the Outback BTS. Remember it just needs to be in the general vicinity of the battery, what I ended up doing with new Rolls that have a similar checkered pattern was to use duct tape to fix it to the side of a battery, half-way in-between the bank so it gets the average temperature.
  • jcheil
    DMJ72 wrote: »
    I'm not sure if that is entirely accurate?
    I was under the impression that it needs the temperature of the BATTERY itself, not the ambient temperature around the battery. Because that temperature differential could be quite a bit.
    Sandwich it between two of the batteries; it will be accurate enough.
  • jcheil
    Preference on position? Top/Middle/Bottom of the battery?
    jcheil wrote: »
    Midway. Diagonal. Vertical.
    Horizontal across the top or bottom would probably be least accurate.
    Stick/glue/caulk a piece of hollowed out insulation (Styrofoam, etc.) over the temp sensor... Good enough on average. Batteries are not going to change 10 degrees / minute--The thermal lag from battery to sensor will not be noticeable, and insulation stops air currents from biasing measurements.
